Author Topic: 10MHz GPSDO by "BH3SAP"  (Read 88552 times)
TechnicalService, Kurt_!, ch_scr, AIfred, Gerhard_dk4xp and 4 Guests are viewing this topic.
Online KungFuJoshTopic starter
  • TEAS is real.
Re: 10MHz GPSDO by "BH3SAP"
« Reply #750 on: September 16, 2025, 07:46:54 pm »
Yes, that seems to be normal.
Best Continuity Tester Ever
Online Kurt_!
  • Country: at
« Reply #751 on: September 16, 2025, 08:10:48 pm »
Maybe I need to change the OSC as well.
I have enough CTI, but whether they are that good?
« Last Edit: September 16, 2025, 08:13:00 pm by Kurt_! »
Oh...my English...
  • TEAS is real.
« Reply #752 on: September 16, 2025, 08:33:37 pm »
Mine is with the ISOTEMP, which I think you said you have?
You can always test other OCXOs. You gotta leave them running at least a few days though.
Online Kurt_!
  • Country: at
« Reply #753 on: September 16, 2025, 09:01:40 pm »
This one is inside OX256B.....
Oh...my English...
  • TEAS is real.
« Reply #754 on: September 16, 2025, 11:44:47 pm »
Oh, yeah, that's not awesome. Murder it!  >:D
Online Kurt_!
  • Country: at
« Reply #755 on: September 17, 2025, 09:19:57 pm »
This diagram is after half an hour of switching on.
no such strange up-down....
« Last Edit: September 17, 2025, 09:22:25 pm by Kurt_! »
Oh...my English...
  • TEAS is real.
« Reply #756 on: September 17, 2025, 10:56:04 pm »
Was that already warmed up? Seems like a lot of initial drift if it was already warmed up. That's the bigger one?
Online Kurt_!
  • Country: at
« Reply #757 on: September 18, 2025, 03:52:53 am »
yes...half an hour
The little one....
always with internal osc and slightly adjusted.
Am Besten du probierst auch das Timelab aus, wenns geht bei dir.
Leo Bodnar also tested something...FA-2
https://www.eevblog.com/forum/metrology/bg7tbl-fa1-frequency-analyzer/msg3868613/#msg3868613
« Last Edit: September 18, 2025, 04:05:48 am by Kurt_! »
Oh...my English...
Offline Ringmodulator
« Reply #758 on: September 18, 2025, 08:04:08 am »
I also  own a a FA-2 and FA-3.
To analyse the ocxo behaviour, it is way better to use a tinyPFA. It als talks to Timelab.
In my opinion, this device has the best bang for the buck.
You can even get a (used) nanoVNA-h4 and flash the tinyPFA firmware.
Thats what I did.
https://www.tinydevices.org/wiki/pmwiki.php?n=TinyPFA.Homepage
Regards
Chris
Online Kurt_!
  • Country: at
« Reply #759 on: September 18, 2025, 10:15:17 pm »
 have a few spares lying around, but I don't want to re-solder until I know which one is best for me.
I already have a good tool, but I don't think it's a good idea to solder too often.
I've already tested their frequencies. How close to 10 MHz they are...but I'm not much of an expert. :D
Ps.:
Are there comparisons ( OCXO ), what is still good and not good
« Last Edit: September 18, 2025, 10:23:14 pm by Kurt_! »
Oh...my English...
  • TEAS is real.
« Reply #760 on: September 18, 2025, 10:46:45 pm »
Thats what I did.
Regards
Chris
Do you mean to compare 1 OCXO vs another at the same time?
« Reply #761 on: September 19, 2025, 11:57:07 am »
Thats what I did.
Regards
Chris
Josh,
Yes and no. You can connect two oscillators and and  compare them against each other, but you cannot determine which one is "better".
This is generally a chicken/egg issue, unless you have a known better reference.
If you have three oscillators, you can measure, which combination has the best stability and identfy  the worst oscillator  of the three.
The videos from Eric, the author of the firmware, may give you an idea of the capability of this device.
Chris
  • TEAS is real.
« Reply #762 on: September 19, 2025, 02:16:49 pm »
Josh,
I'm curious how a phase analyzer would be better to test a single OCXO vs a counter or oscilloscope or spectrum analyzer. I don't know much about the tinyPFA, but I thought the purpose was to analyze and test the phase difference between two signals.
I'll check out the video later.
Thanks,
Josh
Offline ME
« Reply #763 on: September 21, 2025, 11:27:26 pm »
I have an old usb programing cable for programing a motorola gp-340 radio , can i hack that to send nima data to my pc?.cheers Me.
Offline SCSKITS
  • Retired electrical engineer
« Reply #764 on: September 22, 2025, 04:32:06 pm »
An inexpensive GPSDO should be able to do 10MHz +/- 10mHz (10 millihertz). A better one should be able to do +/- 1mHz or 2mHz.
Not sure about the frequency offset you describe, the OCXO module on that board may be able to do +/- 50Hz from 10Mhz. Do they have another IC in line that can shift the frequency? Why would an offset be needed if used as a timing reference?
SCS, DIY upgrades for older test equipment
Online Kurt_!
  • Country: at
« Reply #765 on: September 23, 2025, 06:35:04 am »
In any case, you shouldn't expect too much from used OCXOs!
They don't get replaced after 10 years for nothing!
It's not always the quartz crystal that's to blame, as I've seen in my tests.
The internal electronics are also at fault.
Oh...my English...
The following users thanked this post: ldmpam
Offline flash2b
  • Everything I like about myself is better with you.
« Reply #766 on: September 24, 2025, 01:57:32 pm »
My BH3SAP is +/- 1 mHz (see: https://www.eevblog.com/forum/testgear/10mhz-gpsdo-by-bh3sap/msg5639295/#msg5639295). The new firmware made all the other bits of this GPSDO just so much better.
They say attention is a shovel. It's time to dig 'em out.
Online Kurt_!
  • Country: at
« Reply #767 on: September 24, 2025, 06:38:06 pm »
With Timelab you have better statements and stronger results !
Great program.
Oh...my English...
Online Kurt_!
  • Country: at
« Reply #768 on: September 24, 2025, 07:03:18 pm »
From my FA-3
Gpsdo by BH3sap "The little one"
« Last Edit: September 24, 2025, 07:07:19 pm by Kurt_! »
Oh...my English...
  • TEAS is real.
« Reply #769 on: September 24, 2025, 07:13:01 pm »
My peak to peak is 600uHz, so that's +/- 0.3mHz. Not too shabby. ;)
Online Kurt_!
  • Country: at
« Reply #770 on: September 24, 2025, 07:18:03 pm »
You have two identical GPS devices, right?
Oh...my English...
  • TEAS is real.
« Reply #771 on: September 24, 2025, 08:26:38 pm »
In theory, but one of them might need a repair on the GPS board.  :palm:
Online Kurt_!
  • Country: at
« Reply #772 on: September 24, 2025, 09:10:25 pm »
One can be at peace...
...but an LBE-1421 by Leo Bonar would also be interesting. :D :)
Maybe there will be a promotion sometime?
« Last Edit: September 24, 2025, 09:13:58 pm by Kurt_! »
Oh...my English...
  • TEAS is real.
« Reply #773 on: September 24, 2025, 09:41:43 pm »
The TCXO doesn't really interest me, especially not for the price. If it were in the same price range, then yeah, I'd probably have one already. ;)
Online Kurt_!
  • Country: at
« Reply #774 on: October 11, 2025, 09:51:58 am »
You're right Josh! ( LBE )
I've swapped it twice now.
To CTI and now IsoTemp.
You can tell. Even when testing.
High output voltage and much closer to the target frequency.
« Last Edit: October 11, 2025, 09:53:46 am by Kurt_! »
Oh...my English...
