Author Topic: 8 channel oscilloscope default trace colour schemes  (Read 3268 times)
Offline Scratch.HTFTopic starter
« on: November 12, 2020, 12:44:19 pm »
Currently, I am building an 8 channel variable power supply and I wish to follow a colour scheme for each channel - so far, I have noted the default channel colour codings for 4 channel oscilloscopes (a number of Chinese manufacturers followed the Tektronix scheme of Yellow/Cyan/Magenta/Green which I prefer to adopt), but I am wondering what default trace colours are used for Channels 5-8 on 8 channel Tektronix and other oscilloscopes - for Channels 5-8, Pico uses Purple/Grey/Cyan/Magenta.
If it runs on Linux, there is some hackability in it.
Offline ve7xen
    • VE7XEN Blog
Re: 8 channel oscilloscope default trace colour schemes
« Reply #1 on: November 13, 2020, 12:12:51 am »
Keysight is Yellow, Green, Blue, Red, Cyan, Magenta, Purple Orange
Tek is Yellow, Cyan, Red, Green, Orange, Blue, Magenta, Teal
I don't think any other major brands, even Chinese ones, are making 8-channel scopes right now. It's easy enough to find pictures of these scopes online. There doesn't seem to be a standard, sadly.
Oh Yokogawa apparently has one, it is Yellow, Green, Magenta, Cyan, Red, Orange, Blue, Purple. Different again!
73 de VE7XEN
He/Him
Offline 0xdeadbeef
« Reply #2 on: November 13, 2020, 12:19:54 am »
Really?
The following users thanked this post: JPortici
Offline ve7xen
    • VE7XEN Blog
« Reply #3 on: November 13, 2020, 12:21:20 am »
Really?
Sigh I figured I'd get shown up for that statement  :-DD. I always forget about Lecroy. Probably others too.
They have their own colour scheme too! Definitely can't have our scope's traces looking like another brand's in screenshots!
73 de VE7XEN
He/Him
Offline tautech
« Reply #4 on: November 13, 2020, 12:39:46 am »
But you can.
Many scopes have a full color pallette available to set traces to whatever you want.
If I was the OP I'd set my own standard by starting at one end of the color spectrum and using the shades available.
OR you could use passive device color coding or would that be too easy ?  :-//
Avid Rabid Hobbyist
Offline YetAnotherTechie
  • Country: pt
« Reply #5 on: November 13, 2020, 12:56:52 am »
In the ancient times of HP calculators, colors were picked that color-blind users could distinguish...
I'm not color blind, but would be interested to know if those schemes are good/bad for them.
The following users thanked this post: I wanted a rude username
« Reply #6 on: November 14, 2020, 12:33:15 am »
Thank you for the info, but by manufacturer, what colour correspond to each of Channels 5/6/7/8 respectively?
For Pico, Channels 5/6/7/8 use Purple/Grey/Cyan/Magenta respectively.
Offline JPortici
« Reply #7 on: November 14, 2020, 06:04:41 am »
What i would do: check the color palette available for banana cables and connectors.
Hopefully it will have at least 8 colours, then choose from those, forget about what scopes do.
Offline 0xdeadbeef
« Reply #8 on: November 14, 2020, 10:59:01 am »
Typically the colors of additive and subtractive color mixing are used: blue, green, red, cyan, yellow and magenta. So you have six base colors plus black and white for background and text.
-> If you need 8 colors, you need to either mix colors or modify brightness (which is problematic though if brightness is also used for other things like marking zoom area or so).
IMHO using gray and orange for the remaining two traces would be the obvious choice.
Offline sb42
Offline porker1972
« Reply #10 on: November 18, 2020, 12:41:39 am »
If you're doing it yourself, why not just use the resistor colour code for simplicity?
One thing I do is use the yellow channel on whatever scope I have as it's easiest to see on the screen, but I switch to the red channel to print out as yellow is invisible on paper.
There is a new Keysight scope with 8-channels, the EXR. It is:
1 yellow
2 green
3 blue
4 red
5 cyan
6 magenta
7 purple
8 orange
« Last Edit: November 18, 2020, 12:43:55 am by porker1972 »
Offline ResistorRob
« Reply #11 on: November 19, 2020, 06:30:58 am »
A major scope manufacturer contacted me for input on a future oscilloscope design.
One thing I suggested is offer adjustable color palettes on lower end scopes. Seems like an easy feature to add and would be amazing to have in something besides $10k+ equipment. Would love to see this in something along the lines of a Siglent SDS2000, R&S RTB2004, or Rigol MSO 5000. I would even love to see this in something like a Siglent 1104x-e but I do understand if they make the entry level scopes too good then it will cannibalize mid-range scopes.
Maybe I can get my hacking skills good enough to customize the trace colors on hobbyist and small company scopes  >:D
For my 10th Birthday I got a Fisher Price oscilloscope!
Offline 0xdeadbeef
« Reply #12 on: November 19, 2020, 06:44:32 am »
Hm, at least the newer Siglent scopes (SDS2000X+, SDS5000X) allow changing the trace colors with the last firmware update.
Offline Berni
  • Country: si
« Reply #13 on: November 19, 2020, 06:48:58 am »
Part of the issue with custom trace colors is that often the front panel has some sort of color markings next to the BNCs or the channels controls or color LEDs in the buttons and such.
I don't think any of the modern Keysight scopes have adjustable colors. Maybe there are on the Windows based Infiniium scopes. But the older HP instruments that still run on the 68000 and have color CRTs do tend to have customizable colors. They use a video controller chip that runs in 256 palleted color mode, then each trace and UI element uses a different pallete index. So they simply added a color setting menu that lets you select the palette index and then set the RGB value for it. This means that you can not only change the trace colors but also every single thing in the UI can be tweaked, such as the background, buttons, menus, text colors etc...
Offline Daniel Bogdanoff
  • ALL THE SCOPES!
« Reply #14 on: November 19, 2020, 06:56:46 am »
I *think* you can change trace colors on the Keysight Infiniium scopes. I also saw someone somewhere on this forum swap the color channels to their scope display to mix up the trace colors.
Test and Measurement!
Offline tautech
« Reply #15 on: November 19, 2020, 07:16:43 am »
Yes, like so:
Avid Rabid Hobbyist
Offline Berni
  • Country: si
« Reply #16 on: November 19, 2020, 07:18:21 am »
I can check on my MSO9000 when i get home from work.
Now that i think about it, it would be an awesome prank on my coworokers if i could swap the yellow and blue channels on the X3000 scope at work. I already managed to prank them before on accident by leaving the scope set up with weird triggering and channel settings.
Offline tautech
« Reply #17 on: November 19, 2020, 07:21:34 am »
>:D
Better still, if you can also get into the scopes Default menu and mess with their fav default setup.  :-DD
Avid Rabid Hobbyist
Offline ResistorRob
« Reply #18 on: November 20, 2020, 08:31:41 pm »
Yes, like so:
Tautech, is this possible on the SDS2000X+ ???
I did a google search and found no mention of it. So only available on the SDS5000X ???
If so that really sucks, because I can't afford that.
Offline tautech
« Reply #19 on: November 20, 2020, 08:48:27 pm »
Yes, like so:
Yep, just been added in the recent FW update.  :)
Avid Rabid Hobbyist
