Author Topic: "Count" vs Frequency?  (Read 6833 times)
Offline bitmanTopic starter
  • Open Source Guy jabbing with Electronics
« on: November 24, 2017, 08:26:17 pm »
I have a Rigol 1054 - and I'm practicing to get familiar with the scope and some basic principles.  I have a function generator creating a sine wave at 5KHz and my meter shows it spot on - however initially when I used the scope the count on the top was WAY off (see picture). I then picked "Frequency" on the measurement side and I get the exact number I was looking for.
Question: What's the difference? Why is one number way off? I see a square wave on the count, so I wonder if that has anything to do with anything?
I'm definitely a newbie struggling with some fundamentals here. My quest is to learn, so I'll be happy to be brought to materials that can teach this and other fundamental stuff.
Offline ataradov
    • Personal site
Re: "Count" vs Frequency?
« Reply #1 on: November 24, 2017, 10:34:17 pm »
Count comes from the actual trigger counter. Measurements below are performed on a captured signal.
Try to enable bandwidth limiting in the channel settings. And also try to move the trigger level to 0.
Alex
The following users thanked this post: Fungus, bitman
Offline Bud
« Reply #2 on: November 24, 2017, 11:42:53 pm »
It is a very bad idea to use chinese made garbage to learn the fundamentals.
Offline ataradov
    • Personal site
« Reply #3 on: November 24, 2017, 11:54:18 pm »
I have a surprise for you. American made Teks behave exactly the same.
Alex
The following users thanked this post: Fungus, newbrain
« Reply #4 on: November 25, 2017, 12:25:18 am »
Worked like a charm. Make quite a bit more sense now.
Offline Fungus
« Reply #5 on: November 25, 2017, 09:49:46 am »
Welcome to the Internet, bitman.
Offline Fungus
« Reply #6 on: November 25, 2017, 10:05:33 am »
They're both calculated differently.
The number at the bottom is calculated from the data on screen. The value will depend on your zoom, the number of visible waves, the noise on those waves, etc. This is usually the preferred number, although you always need to bear in mind what's visible on screen (eg. it won't work at all if there's only half a wave visible).
The number at the top comes from the trigger circuit. It counts the number of times the trigger was fired per second. If there's noise on the signal you might get extra counts as it wobbles past the trigger voltage level. This is why turning on the bandwidth limiter can help - it's a low pass filter on the input and can help a lot with the accuracy of measurements when you're looking at low frequency signals.
Note: Neither of these methods is guaranteed to be 100% accurate in all circumstances. That's oscilloscopes for you.
(Note to Bud: this is true of all oscilloscope, not just this one).
You can also take measurements manually. Capture a single wave on screen with as much zoom as possible. Turn on cursor mode. Move the cursors to the start and end of the wave you just captured.
That's just a graphic, nothing to do with anything.
« Reply #7 on: November 25, 2017, 12:27:39 pm »
Just a point with the DS1054Z counter. It is pretty accurate. I've used mine to align radios quite happily when I couldn't be bothered to dig a cable for the counter out.
If you're going to measure frequency of your function generator however, connect the sync output (if it has one, if not separate square wave output) to channel 4, tell the scope to bind the counter to channel 4 and use that instead. Also set your trigger to trigger on the sync output as well. Sometimes it's easier to measure and trigger on a reference signal on the generator than the actual signal you're looking at. If for example you turn your sine amplitude down below the trigger threshold or you want to move the probes to different bits of the circuit then it'll still trigger fine and you can make realistic measurements. Also you can use phase measurements against a reference point then as well so if you run your signal through a filter you can measure what happens.
:palm:
They work fine and are affordable.
Offline jpb
« Reply #8 on: November 25, 2017, 12:52:41 pm »
On my scope (WaveJet) the hardware trigger counter is much more accurate than the values from the displayed waves - it reads to 6 sf and is only about 2 counts down (when compared to my standalone counters and gps OCXOs). The screen values are much more approximate (4 sf at most) and vary up and down by relatively large amounts.
And, as you say, the screen ones are very dependent on what is being displayed.
Offline Fungus
« Reply #9 on: November 25, 2017, 01:15:02 pm »
Yes, they can be. It depends on the amount of noise on the input.
They certainly have more digits.
« Reply #10 on: November 25, 2017, 04:16:41 pm »
Thanks but I cannot help chuckling. I haven't heard that since the mid 1980s ...  (and since then, it's been what I've told others). While I'm new in electronics I'm not new in IT or by any means "young". Just a hobby I wasn't able to pursue when younger. I've been around the block many many times when it comes to stupid stuff on the net - this is mild and frankly I barely noticed it had it not been for "you guys" repeating it.  And yes, you read the time right. I was online before most knew what the internet was, before browsers - heck I didn't even use PCs :)  Anyway if you can imagine it, I've seen it online.
I've lurked for quite a while here, asked a few dumb questions in "beginners" and by far this has been enormous helpful in getting me on the right track when I screw up. I see very little noise and amazingly a very high percentage of on-topic replies/posts. Kudos to everyone here and the admins for keeping things flowing and useful. And thanks for having me :)
Offline effectivebits
« Reply #11 on: November 27, 2017, 12:22:31 am »
You want to measure frequency where the slew rate is the fastest.  Near the top of a sinusoid is the wrong place to do it.  Notice that your measurement is made at the 50% point, but your "frequency counter" appears to be near the top.
I'd recommend you move your Trigger Level to the middle of the waveform and try again.
Joel Avrunin
« Last Edit: November 27, 2017, 01:00:03 am by effectivebits »
