Author Topic: A call for Bin-Files as for new Siglent HD-Models  (Read 2021 times)
Online Performa01
  • Country: at
Re: A call for Bin-Files as for new Siglent HD-Models
« Reply #25 on: March 09, 2024, 07:08:12 am »
I tried a spectral analysis of SDS824X_HD_Binary_C4_1.bin (as posted by Performa01, 100M points, 2GSa/s, 500µV/div) with Welch's method (2M window size, 80% overlap), and it results in a very similar shape as the SDS824X_HD_ND_2GSa_1mV screenshot (although calculated from a different data set).
[ PS: The plot is just calculated from the raw sample values, so the absolute vertical scaling is not yet correct.
I was too lazy yet to find out how to find the scaling factor from raw sample values to Volts in .bin file header. ]
EDIT: Does anybody know the "code_per_div" value for the SDS800X?
The value 25 from the following paper obviously applies only to 8-bit samples.
https://siglentna.com/wp-content/uploads/dlm_uploads/2021/09/How-to-Extract-Data-from-the-Binary-File.pdf
Is it 256*25=6400 for 16-bit samples? (just a guess)
Thank you very much for your effort!
The binary file should be in "V4" format, as described in chapter "SDS2000X HD | | SDS5000X After 0.9.6 | | SDS6000 After 1.4.1.0" in the application note "How to Extract Data from the Binary File of Siglent oscilloscope", E02A that you've already using.
I have not looked closely, but this document doesn't seem to be perfect, otherwise I would have said you should just treat the SDS800X HD like a SDS2000X HD. In any case, I've already asked for that document to be revised.
I can tell you for sure, that the SDS800X HD has 480 codes per division like the SDS2000X HD, not 25 like the ancient 8-bit SDS1000X.
EDIT: oh, and it might well be that you need to upscale this value to 16 bits: 480 * 2^16 / 2^12 = 480 * 16 = 7680;
« Last Edit: March 09, 2024, 07:12:41 am by Performa01 »
The following users thanked this post: egonotto, gf
Online gf
« Reply #26 on: March 09, 2024, 01:06:03 pm »
I the mentioned document I found (from 2021), there are no HD models considered at all.
Does a new version exist?
Thank you, 7680 gives plausible results. I'll update my previous plot with this scaling.
The following users thanked this post: Performa01, egonotto
Offline 2N3055
  • Country: hr
« Reply #27 on: March 09, 2024, 02:00:42 pm »
You should stick to EU server  :o
https://www.siglenteu.com/wp-content/uploads/2021/08/How-to-Extract-Data-from-the-Binary-File.pdf
This is version Perfoma and myself are referencing.
Vertical scaling value is contained to in file, per channel
« Last Edit: March 09, 2024, 02:03:17 pm by 2N3055 »
The following users thanked this post: Performa01, egonotto, gf
Offline m98
« Reply #28 on: April 01, 2024, 05:30:52 pm »
Any chance someone has already written a python/matlab/etc. parser for the sds2000x hd bin format?
