Hi all
I have a r3361 advantest spectrum analyzer and want to feed it with an external 10 MHZ reference signal through it's rear panel input.
There is a switch selecting if the bnc connector will be inputing or outputing the 10 mhz reference but I cannot see a menu selection to enable or disable the external reference mode
If switch is at the "external input" and my 10 mhz signal is missing there is not any "UNLOCK" indication so I can be sure if it works ok....
Does it automatically reverts to the internal reference if external is missing? Am i missing something?
Thanks
Stavros
