Author Topic: Affordable micro-grabbers  (Read 4295 times)
Online perdrixTopic starter
« on: September 02, 2021, 03:20:16 pm »
I'm sure the Pomona 72902 test kit is excellent but at £250 plus VAT it ought to be!!!
Does anyone know of a source for similar micro grabbers at a less eye-watering price?
The older Tek and HP ones are too large.
Thanks
Offline Fungus
Re: Affordable micro-grabbers
« Reply #1 on: September 02, 2021, 03:49:07 pm »
Offline bingo600
« Reply #2 on: September 02, 2021, 03:55:57 pm »
Do NOT get these
https://www.aliexpress.com/item/32924136849.html
The metal clip part slips off the "subject leg"
/Bingo
Offline Markus2801A
  • Country: at
  • Pobody’s Nerfect ;-)
    • KEM InfoPage
« Reply #3 on: September 02, 2021, 03:56:42 pm »
Teacher for electrical Engineering @ HTL and Werkmeisterschule :-)
The following users thanked this post: Kean
Offline kripton2035
« Reply #4 on: September 02, 2021, 05:19:02 pm »
the SDK08 are nice, and very small. may be too small for some DIP pins. ok for SO or even TSSOP.
Offline JimKnopf
« Reply #5 on: September 02, 2021, 08:37:59 pm »
I use EZ-HOOK XKM-S.
Offline LaurentR
« Reply #6 on: September 03, 2021, 12:03:36 am »
There are lots of NOS Tek grabbers on EBay like these ones:
https://www.ebay.com/itm/234094788223
I bought myself a bag and I am indeed set forever. You can find a better price than the link above with some patience (I have seen ~$20 a bag).
Offline Ground_Loop
« Reply #7 on: September 03, 2021, 09:33:47 am »
You can find old MJ-033 clips on EBay. The hooks are strong and have smooth operation. Otherwise, Pomona or EZ Hook.  Stay away from the cheap ones.
There's no point getting old if you don't have stories.
Offline Doctorandus_P
« Reply #8 on: September 03, 2021, 08:14:09 pm »
I was impressed by the "SDK08" and ordered some too.
Offline thm_w
  • Non-expert
« Reply #9 on: September 03, 2021, 09:41:30 pm »
SDK08 are great if we are talking about SMD pin usage. I used them side by side on a TSSOP.
Managed to destroy one, partially my own fault, pushed the back pin in too hard I think.
If you are in canada the cost is a bit lower here: https://www.banggood.com/10Pcs-SDK08-Test-Clip-SMD-Grippers-Test-Clips-Ultra-Small-Clip-Foot-Clip-Micro-Chip-Online-Burning-Clip-p-1823454.html
« Reply #10 on: September 04, 2021, 01:17:11 am »
Yep them Tek ones are great but a little hard to find cheap or in small lots however not by having identifying attributes they need be connected to colored fly leads for channel ID.
Otherwise these seem reasonable:
https://www.ebay.com/itm/Goupchn-Mini-Grabber-SMD-IC-Test-Hook-Clip-Jumper-Probe-for-Logical-Analyzer/133521515268
Avid Rabid Hobbyist
The following users thanked this post: Markus2801A
