Hello all,
I recently got myself an 16702A that apparently used to be owned by Motorola and was involved in pattern generating. I'm basing this assumption that despite it having a pair of 16712A analyser cards the cables for those are bundled up in the pouch looking like new and the pattern generator card has a full compliment of cables installed that are labelled for use.
Unfortunately it came with no flying probes or grabbers, but I have a fully populated HP1660a I can thieve pods from.
Its Quantum SCSI drive was toast so I'm using a BlueSCSI desktop unit from earlier in the year, latest firmware. I downloaded the Ignite image thanks to the fine folks here and copied it to the SDCARD as ID 0, and also created an empty 4.5GB image to live at SCSI ID 6 for the Ignite process. When booting it sees everything and I can boot from the CD image with no issue. It will also boot from an external SCSI CDROM I have from back in my DEC days. The install runs through reasonably quickly but it gets to this point and sits there for hours; so far I've left it for 3.5h and it doesn't move.
If I'm booted from external CDROM it will also stop here but the activity light will blink every so often.
It's only installing the VUE desktop, any reason for it to pause/stop here?
Cheers
Adrian
