Author Topic: Power supply Matrix MPS 3005H review.  (Read 1507 times)
Offline rauldmTopic starter
  • Country: mx
« on: July 24, 2021, 02:16:58 am »
Hi everyone, I bought a new power supply from amazon, the brand is Matrix MPS 3005H.
Specifications.
-Two regulated power supply of 30V-5A, maximum 31V-5.1A
-Single fixed power supply of 5V-3A.
-Parallel, series and independent modes supported.
Highlights.
-Encoder type knobs, this feature is incredible because lock the value, you need push and turn knob for change value for current or voltage.
-OVP and OCP settings, this part I like it, because in OCP mode is very useful for me, fix a current value if limit is overpased, output turn off.
-Output botton independent for each power supply except fixed power supply.
-Start  with programed modes, you can select if you want the power supply turn on with outputs on or off, turn off beep, or fix limits for voltage and current.
-Toroidal type tranformer.
-Low noise.
-Comes with three 4 mm plug alligator cables and printed user manual.1238891-0
I think this power supply it has good quality for price range, I paid around 200 USD for it.
Only bad thing with this power supply is the fan noise, fan is activated automatically by temperature.
I hope your comments.
« Last Edit: July 24, 2021, 02:33:16 am by rauldm »
  • Country: mx
Re: Power supply Matrix MPS 3005H
« Reply #1 on: July 24, 2021, 02:19:29 am »
Noise with 110 Watt
« Last Edit: July 24, 2021, 02:23:52 am by rauldm »
Offline Analog4
« Reply #2 on: July 25, 2021, 07:06:06 am »
You might check out alternative fans.
My MATRIX TECHNOLOGY MPS-6005D+, Variable Linear Regulated Adjustable DC Power Supply had a noisy fan. I replaced it a different fan, which seems to work fine and is much quieter:
GDSTIME 80mm Fan, 80mm x 80mm x 15mm 24V DC Brushless Cooling Fan Sleeve Bearing, Part #   GDT8015S24V2P2.54FS
Noise Level    31 dB, Rated Speed: 3000RPM; Air flow: 35.6 CFM
Check your power supply to see if there are alternative fans that might work. I think a noisy of the fan was not a design priority for the Matrix manufacturer.
The following users thanked this post: rauldm
  • Country: mx
Re: Power supply Matrix MPS 3005H review.
« Reply #3 on: July 26, 2021, 10:28:23 pm »
Hi, Thanks for your answer, I will try put other fan, really is noisy, what do you think about your matrix PS?
Regards.
