Author Topic: Agilent DSOX 2000 Aliasing  (Read 2815 times)
Offline KD0RCTopic starter
« on: December 17, 2014, 12:42:25 am »
I discovered a way to get my Agilent DSOX 2022A to alias on a 10 MHz signal.  I made a short video showing the effect.  This only happens when the scope in in FFT mode, so I am wondering if this is a bug, or inherent in getting FFT to work.
@EEVBLOG - Dave, maybe you could do an EEVBlab on whether your DSOX 3000 series scope shows the same behavior.  I would also be interested in your opinion as to whether this is a bug, or a necessary artifact to create the FFT display.
@W2AEW - Alan, do the TEK scopes do this as well?
Here is a link to the YouTube video.
http://youtu.be/JcvckkCutJU
Comments welcome!
Len
Online MarkL
Re: Agilent DSOX 2000 Aliasing
« Reply #1 on: December 17, 2014, 01:28:19 am »
The Agilent scopes do random decimation to reduce the possibility of aliasing.  However, it turns it off while doing FFT and some of the other math functions so that they operate normally without this added noise.
It's been discussed on Agilent/Keysight's forum:
  http://www.keysight.com/owc_discussions/thread.jspa?messageID=108399
(which then refers back to some posts here on the eevblog).
« Reply #2 on: December 17, 2014, 02:54:34 am »
Thanks Mark.  I should have guessed that I would not be the first to find this...
Len
