Author Topic: Agilent FieldFox 9912A option hack?  (Read 7614 times)
Offline nexusTopic starter
« on: August 10, 2021, 03:49:29 pm »
Hey all,
Had a question to pose to the general community. These handheld microwave analyzers come with all hardware inside, but are heavily crippled through the typical license paywalls.
Older Agilent handhelds are vxWorks based as far as I can tell. There also are serial port connections on some boards that allow you to open a shell and get some options happening.
Has anyone made a pass at a FieldFox before? Base units do cable (distance to fault) and one-port analysis only. Spectrum analysis and two-port vna is all option based in software.
Any anecdotes would be appreciated! The best inside-pics I could get were from another post where a fellow blogger replaced his RTC batt: https://www.eevblog.com/forum/repair/agilent-fieldfox-n9912a-6-ghz-rtc-battery-swapquick-repair/
Re: Agilent FieldFox 9912A option hack?
« Reply #1 on: August 10, 2021, 05:54:13 pm »
Roger. I suppose that means I need to buy one first.
Someone on here went and nabbed the $3500 one on ebay shorty after I started this topic..
Online coromonadalix
« Reply #2 on: August 10, 2021, 07:07:19 pm »
EEVblog is now .... well known   |O
Offline TheSteve
  • Living the Dream
« Reply #3 on: August 10, 2021, 08:19:35 pm »
The FieldFox runs WinCE.
Some other basics:
If they are Agilent branded, or Keysight branded with a white label then they run an older/slower CPU board. If they have a red Keysight badge they use a newer much faster processor board. The faster processor board models have more features such as an RTSA.
The N9912A(SA, very basic VNA) and N9923A(full 2 port VNA, no SA) are of an older design, the other models all run upgraded and better RF hardware.
« Last Edit: August 10, 2021, 08:23:12 pm by TheSteve »
VE7FM
« Reply #4 on: August 11, 2021, 02:09:17 am »
I wish basic VNAs were more attainable the way good entry level SAs have started to become. You can pick up a second hand RSA306 for 1.5K if you shop around and wait on ebay. A used TTR503 fetches an eyewatering 7k+.
Just having difficulty deciding whether its even worth trying to buy a VNA under $5K that has the following attributes:
2 port (min. S11, S21)
>= 6GHz analog bandwidth
> 90dB dynamic range across entire bandwidth
plus: not a massive boat anchor
Offline TheSteve
  • Living the Dream
« Reply #5 on: August 11, 2021, 02:34:35 am »
The boat anchor part is a good challenge - my 8753E 6 GHz was very nice, and not that heavy compared to a lot of gear. Still it was a decent size. Now I get by with a very nice Fieldfox :)
VE7FM
« Reply #6 on: August 11, 2021, 04:09:43 am »
So Mr. Fox, any way to get that performance without robbing a bank? Not like showing up in a mask would be suspicious now though...
Offline TheSteve
  • Living the Dream
« Reply #7 on: August 11, 2021, 06:02:55 am »
Mine was blessed with licenses from Keysight.
VE7FM
Offline tgetec
« Reply #8 on: May 24, 2022, 12:58:51 pm »
Anyone installed 30-day Trial Options? What if the RTC is no longer powered?
Since it is not possible to modify the system time by more then 6hours backwards per day, it looks to me that the trial licenses are validated against the RTC date.
I read the RTC time is resetting on every power down here:
« Last Edit: May 24, 2022, 01:04:40 pm by tgetec »
Offline felixsys
« Reply #9 on: June 01, 2022, 01:31:12 pm »
I removed the RTC battery but strangely the device continues to normal clock operation and doesn't reset the data/time.
of course I removed also the battery pack.
If someone knows where I can find the RTC IC.. I would like to remove it to test it :)
Offline Alexander0
« Reply #10 on: July 13, 2023, 02:58:47 pm »
Hello,
how are you doing? were you able to drop RTC time?
Offline matthieu.e
« Reply #11 on: November 16, 2025, 08:14:46 pm »
Does anyone succeed to add option on the FieldFox 9912A ?
Offline khanda
  • Country: cn
« Reply #12 on: June 16, 2026, 03:54:37 am »
If you need to add options to the handheld spectrum, please send the model and serial number in the replies to this post.
Online koenz
« Reply #13 on: September 04, 2026, 04:25:04 pm »
I am checking if i want to buy this model. could you give me more info about the options?
MODEL: N9912a-AT0-5938
Thanks,
Koen
« Last Edit: Today at 10:38:56 am by koenz »
Offline khanda
  • Country: cn
« Reply #14 on: September 17, 2026, 01:06:40 am »
Yes,I can
The following users thanked this post: roxbox
Offline davide10
« Reply #15 on: September 18, 2026, 03:49:22 pm »
Hello khanda can help whit add 231 and if is posible 235 opción. Thanks for help im hot hable to contacto whit mesage i atach Image whit detalla
Offline Schlammkuh
« Reply #16 on: September 18, 2026, 10:23:36 pm »
Can you help me too?
I would like to use my recently acquired FieldFox to check some common wireless communication systems, like Wifi, LTE, 5G, Bluetooth.
The model number is: N9914B
Serial: MY63185242
My unit already came with the spectrum analyzer option 233.
I'm particulary interested in the following additional options:
030   Remote control capability
235   Pre-amplifier
236   Interference analyzer and spectrogram
307   GPS receiver
312   Channel scanner
350   Real-time spectrum analyzer (RTSA)
351   I/Q analyzer
355   Analog demodulation
370   Over the air LTE FDD measurements
377   Over the air 5G TF measurements
B10   Bandwidth, 100 MHz
378   Over-the-air (OTA) 5G NR measurements
352   Indoor and outdoor mapping
391   Directional Finding - Angle of Arrival (AoA)
371   Over the air LTE TDD measurements
Regards,
Sebastian
« Last Edit: September 18, 2026, 11:08:29 pm by Schlammkuh »
Offline khanda
  • Country: cn
« Reply #17 on: September 20, 2026, 08:44:17 am »
I’m very sorry, but some people have been taking the files I provided free of charge and reselling them elsewhere. Because of this, I’m no longer able to provide this type of support.
If you need the option files or related support, please contact Keysight directly.
Offline davide10
« Reply #18 on: September 21, 2026, 04:25:55 am »
There is no such tool; those are just posts aimed at boosting the movement of stock. That’s my opinion. We have to wait until something truly functional comes out.
Offline Schlammkuh
« Reply #19 on: September 21, 2026, 09:54:56 am »
Well I think there might be. Its just some kind of mathematical formula, based on the serial number of your device. From this, it calculates a key, which is then included with the option number you like to have and model number. For a technician who installs a couple of licenses for customers it might be possible to reverse engieneer the algorithm.
Offline Schlammkuh
« Reply #20 on: September 21, 2026, 09:56:22 am »
You need to have 10 posts to be able to send/answer PMs. I have the same problem right now.
Offline davide10
« Reply #21 on: September 21, 2026, 09:57:00 am »
Thanks
