Author Topic: Rigol's New DHO800 Oscilloscope unbox & teardown  (Read 564501 times)
0 Members and 27 Guests are viewing this topic.
Offline norbert.kiszka
Re: Rigol's New DHO800 Oscilloscope unbox & teardown
« Reply #2175 on: May 19, 2025, 02:33:54 pm »
Mine is from this link and is working fine.
It came with Chinese power cord, which can be replaced and with Chinese menu, which can be switched to English or any other supported language.
I bought it for about 380 euro, including the shipping, from the EU warehouse, now it is under 340 euro with a coupon...
Same with mine, purchased almost a year ago -- it's working without any problems. Interesting fact: The current offer lists the power brick not included, maybe that's the reason for the lower price. Maybe these are really manufacturer rejects that get shipped incomplete due to a QC failure? Just wondering...
And maybe that's the reason of problems with such scopes from such sellers.
Online Martin72
« Reply #2176 on: May 19, 2025, 05:32:17 pm »
I also think these are returns/grey imports that are being sold off there.
That's why the brand name has been omitted.
Offline ptluis
  • Country: pt
« Reply #2177 on: May 19, 2025, 06:18:24 pm »
Mine burn in 10 minutes...
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #2178 on: June 17, 2025, 10:26:19 pm »
Today we got a DHO924S that we ordered yesterday. It does decode I2C - which fails on another Rigol we have.
Image shows measurement of a 22 mV signal from the built-in generator. I made an attenuator with a 50R and a 1K resistor, so the signal at the scope input is 1 mV. The image looks good, but a video would reveal more low frequency noise. Trigger is stable with that small signal. Nice tool!
I managed to download a firmware update, something that also failed with the other Rigol.
Regards, Dieter
« Last Edit: July 15, 2025, 04:48:53 pm by dietert1 »
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #2179 on: June 18, 2025, 04:23:31 pm »
Upgrade and subsequent self-calibration have been finished. Today i got this nice FFT check, so that appears to work as well. For that i changed the signal generator waveform to rectangle. With the new firmware the diagrams got those x and y axis labels that weren't there before. One can turn them off under Menu -> Display.
Regards, Dieter
« Last Edit: June 18, 2025, 04:26:09 pm by dietert1 »
Offline nightynight
« Reply #2180 on: July 01, 2025, 09:28:10 pm »
Hello everyone, I'm in the process of troubleshooting a DHO804 oscilloscope. I'm trying to identify the integrated circuit marked in the attached photo — it's located near the USB-C port, in the corner of the board. Does anyone recognize this IC or know what voltage should be present at the marked test point? Based on the surrounding components, I suspect it's a buck regulator, but without a second working unit for reference, it's hard to determine the expected output voltage. Any insights would be greatly appreciated.
« Reply #2182 on: July 02, 2025, 12:02:05 pm »
I measured all those three point on my DHO924S.
Those series quite often has cold joints. Try to resolder this IC with leaded solder and with some good flux. Maybe also other smallest components around it.
Offline nightynight
« Reply #2183 on: July 02, 2025, 08:02:49 pm »
Thank you all for your support. I’ve desoldered the IC — it has a short circuit between VIN, SW, and PGND. I’ve placed an order for a replacement, but due to limited availability, I was forced to source a few units from a well-known online marketplace starting with 'A'.
Offline vik-lob
  • Country: by
« Reply #2184 on: July 03, 2025, 01:11:51 pm »
2605923-0
Please tell me what kind of microcircuit is circled in red?
« Reply #2185 on: July 03, 2025, 01:15:10 pm »
For 99% this is LDO for ADC.
Offline vik-lob
  • Country: by
« Reply #2186 on: July 03, 2025, 01:59:05 pm »
Can anyone tell me the datasheet for it?
Offline any1ne
  • Country: ru
« Reply #2187 on: July 15, 2025, 10:03:13 am »
Maybe someone knows?
Maybe MPQ8904DD?
Offline vik-lob
  • Country: by
« Reply #2188 on: July 15, 2025, 03:12:49 pm »
Looks very much like the truth. I'll check the pinout on the board and give a report. Thanks in advance.
« Last Edit: July 15, 2025, 03:16:31 pm by vik-lob »
Offline vik-lob
  • Country: by
« Reply #2189 on: July 17, 2025, 05:19:55 pm »
The MPQ8904DD chip corresponds to the chip on the T3SJ board. (In the photo above).
Offline vik-lob
  • Country: by
« Reply #2190 on: July 17, 2025, 05:25:41 pm »
I soldered a 330 kOhm resistor on top, to the resistor near the microcircuit (19C). And the voltage returned to normal - 1.2 V.
Offline jackcheng
  • Country: cn
« Reply #2191 on: September 21, 2025, 06:13:21 am »
HI AndyBig,
How did you increase the bandwidth to 420Mhz? I have update the vendor.bin to model 924 and enable all the option. But only get about 250Mhz (1.4ns rising time).
Could you share how did you do this? Is it related to inductance?
Offline SP3TA
« Reply #2192 on: October 15, 2025, 08:12:52 am »
 There is some info on Russian forum, that decreasing inductances in front of ADC (all 4 of them - this is CLCL balanced lowpass, see photo: two channels on the right are modified) to 12nH* will rise BW to about 500 MHz - at least at 446MHz is on the similar level, than 100MHz, for reference.
* exact PN used: Murata LQW15AN12NJ00D
2677247-0
But I have another question: Has anybody identified all DC converters IC powered directly from USB-C connector? I'm building converterless battery pack and wondering, if I should play safe and stick to 3S configuration, or use 4S with 16.8V on fully charged pack. 🤨
« Last Edit: October 15, 2025, 02:01:51 pm by SP3TA »
« Reply #2193 on: October 21, 2025, 03:23:58 pm »
Some DC-DC converters are powered directly from USB-C and some are after one transistor which is used to power on/off (almost) whole scope.
From what I seen on this forum, 15.5 V is the maximum safe voltage. 12 V makes those converters less noisy and more efficient.
I suggest to use LiFePO4, because those are much much safer.
If You want to modify or bypass LC filters, You need to maintain proper line termination, otherwise You will have bad pulse response and reflections.
Offline Alwaily_iq
  • Country: iq
« Reply #2194 on: December 08, 2025, 07:55:41 pm »
Hello everyone,
I recently received a Rigol DHO802 from a friend. He originally bought it, but after encountering issues, he tampered with the system files on the internal SD card/storage, which resulted in the device failing to boot (Black Screen).
now, I am facing a problem with my Rigol DHO802. i used your .img files and the device powers on normally and boots into the system without issues. However, the oscilloscope fails to capture or display any waveforms. It constantly shows the message: "No signal detected".
Troubleshooting steps I’ve taken:
Checked the probes and power supply (all are original and working fine).
Ran the internal "Board Test" in the settings.
The test returned the following error: spu.ddr fail.
Does anyone know what causes this specific error and how to restore the signal functionality?
Thanks in advance.
Online thm_w
  • Non-expert
« Reply #2195 on: Yesterday at 01:15:25 am »
A DHO804 for 350€ incl VAT....
https://www.banggood.com/de/DHO804-Digital-Oscilloscope-70MHz-4-Channel-12-Bit-1_25GSa-or-Sec-25MPts-Depth-Convenient-1,000,000-wfms-or-s-HD-Touch-Screen-p-2006738.html?cur_warehouse=CZ
But the name was deleted on the pics.....Smells fishy.
I'm sure its legit, ali has <$330 shipped for DHO804 ($20 coupon currently): https://www.aliexpress.com/item/1005008117005981.html Though there is gamble whether you'd pay taxes or not in NA. I paid $300 for the DG821 pro shortly after release and retail is $400. Grey market pricing.
