Author Topic: Agilent/Keysight U1253B display becoming unreadable...  (Read 11901 times)
Offline nickds1Topic starter
« on: April 14, 2018, 07:05:56 am »
I have a very lightly used U1253B DMM - not a cheap meter...
Suddenly, in the last few weeks, the display has faded to being very dim indeed - it's not the brightness setting - that's on MAX.
It's readable, but only just.
What can I do about this? Agilent/HP used to be a byword for quality and I've always been an advocate for their kit, but this is just very poor - was there an issue with the OLED displays?
This unit was only bought in July 2012 and has never been out of the lab... really rather annoyed by this - it's my main non-bench DMM. And expensive.
What are my options?
Many thanks
« Last Edit: April 14, 2018, 01:04:30 pm by nickds1 »
Re: Agilent U1253B display becoming unreadable...
« Reply #1 on: April 14, 2018, 07:56:37 am »
OLED has finite life span. Have avoided the hell out of them myself. AFAIK not much you can do. Worth whining to Keysight about it but after 6 years you’ll be lucky if you get anything out of them other than a repair bill.
To be honest Keysight stuff is top notch still just OLED displays were a bad tech choice. I went for a cheaper VFD based meter from GW in the end. Longer lifespan.
« Last Edit: April 14, 2018, 07:58:09 am by bd139 »
Offline nanofrog
« Reply #2 on: April 14, 2018, 09:07:44 am »
Although Keysight's answer to a dead/dying OLED is buy a new meter, members here have finally sussed out the OLED being used. So it's possible to repair it (for now anyway).  :phew:
Check out the Replacement Part Found for U1253B OLED Screen thread.  ;)
« Reply #3 on: April 14, 2018, 12:25:15 pm »
OLED displays are supposed to have a minimum lifespan of around 14,000 hours, or 5 years at 8 hours a day - this meter has only a tiny tiny fraction of that in hours.
Really very disappointed in Agilent - it seems to be a known and common issue - manufacturing flaw. Yes, people can argue about the wisdom of buying an OLED meter in the first place, but what I bought was "Agilent", and it's definitely sub-standard - even my sacrificial cheap Chinese meters at a twenty fifth of that cost last longer than that.
The replacement part is about GBP 80 - it should be free to those who've spent a truck load of their own money on a poorly designed bit of kit - Fluke give a lifetime warranty on their kit (actually it's 7 years from when they last made that device). Agilent, take note.
Offline nanofrog
« Reply #4 on: April 14, 2018, 12:49:20 pm »
I highly doubt those displays were made to those specs though, given what's been reported by owners of the OLED models (suspect they're an earlier generation).
« Reply #5 on: April 14, 2018, 01:00:38 pm »
This is a current model DMM - Keysight are still selling them...
...which begs the question: Are they still selling DMMs with rubbish OLED displays?
One would HOPE that the current stock (and replacement displays) are longer life that the original stuff...
Anyone from Keysight care to comment on this?
Offline Joel_l
Re: Agilent/Keysight U1253B display becoming unreadable...
« Reply #6 on: April 14, 2018, 01:10:33 pm »
This thread might help you if you decide to replace the OLED yourself. It's the A model, not sure if the actual display changed.
https://www.eevblog.com/forum/testgear/replacing-oled-screen-on-an-agilent-u1253a-multimeter/
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #7 on: April 14, 2018, 01:27:26 pm »
The fact it started so suddenly makes me believe the meter itself may have a defect other than the display. Unfortunately it may be difficult to solve without proper schematics.
I am not sure if the earlier design has anything to do with it (or perhaps simply older age), but so far it seems quite concentrated un the older Escort design U1253A/B. There is only one report (that I can recall) of someone with OLED issues on the newer generation U1273A.
Online Fungus
« Reply #8 on: April 14, 2018, 02:35:42 pm »
That's only the LEDs in it.
They also have to be perfectly sealed so that not even a single molecule of water can get inside but they're rarely that good in practice. This gives them a limited shelf life as well as a limited number of hours of use.
Online Fungus
« Reply #9 on: April 14, 2018, 02:39:42 pm »
Most people who buy an expensive meter plan on using it a lot.
They probably are because manufacturing improves all the time.
This is a known problem with all OLEDs though. They simply don't last a long time.
(...and this raises the question of why Keysight don't use TFT screens)
« Reply #10 on: April 14, 2018, 04:31:02 pm »
Note sure what point you're trying to make here - I'm a professional EE but am working about 3,500 miles from my labs at the moment... I have an "away kit", so some stuff is duplicated... a lot of the "home kit" only gets used for a few weeks a year (if that).
How much I may or may not use the device is completely irrelevant - Agilent/Keysight made a bad call on these devices and should pick up the tab. Fluke would have.
« Last Edit: April 14, 2018, 04:49:07 pm by nickds1 »
Online Fungus
« Reply #11 on: April 14, 2018, 04:47:07 pm »
Simply that in a meter that gets used a lot it doesn't matter if the screen only lasts 5 years (or whatever).
Agilent/Keysight made a bad call on these devices.
No disagreement there.
But... given the awful battery life and unreadability in bright light (among other problems) they seem to be aimed at the "Oooh, shiny!" buyer, not people who need to depend on a tool to get a job done.
PS: They also make them in plain LCD versions.
Fluke would have.
Fluke would never have made an OLED meter in the first place.
« Last Edit: April 14, 2018, 04:49:52 pm by Fungus »
Offline nanofrog
« Reply #12 on: April 15, 2018, 01:28:27 am »
The display manufacturer may not have improved their processes or equipment however, so current production may still be the same as when they first were available for sale to Escort.  :( Even if this is the case, I get your anger/frustration as they should have sought out an improved OLED for it or EOL'ed that particular model. Personally, I suspect greed is the reason why nothing has been done.
Not ideal of course, but you can at least replace the display and get it working again (linked thread has the P/N & sources to obtain one).
For disclosure I own an Agilent labelled U1252B.
Perhaps replacing the OLED, selling it, and replacing it with a different meter would be worth it in order to eliminate any further aggravation over this issue.
« Reply #13 on: April 16, 2018, 12:32:55 pm »
One way of still using the meter, even without a display, would be to buy the Bluetooth adapter (good money after bad?) and use the free Android or IOS app to display the result.
Bleugh...
I'm in contact with Keysight customer support - I'll report back on their performance...
« Last Edit: April 16, 2018, 01:02:17 pm by nickds1 »
Offline Keysight DanielBogdanoff
  • ALL THE SCOPES!
    • Keysight Scopes YouTube channel
« Reply #14 on: April 17, 2018, 08:27:34 pm »
First off, I'm so sorry to hear that you are having this problem!
So, I'm not familiar with the design side of things and can't offer much more than what's already been said on the OLED display failures.
I can say, though, that our design teams are required to use industrial-grade parts. For example, the 3000T oscilloscopes use an 8.5" capacitive touch display. The screen alone costs more than many 8.5" tablets on the market. So, I'm confident that the part being used isn't a consumer-grade part.
The display board is orderable, but it's roughly $100
https://community.keysight.com/thread/25646
« Reply #15 on: April 18, 2018, 10:03:26 am »
Hi - I appreciate the reply - I'm aware of the replacement board, but as you note, it's $100 + Tax & Shipping, and should not be necessary.
By any measure, this is a poor design choice by Agilent/Keysight and I'm pretty cross (as are a lot of people who are in the same position) that their trust in the company has been shaken.
I have had one email from Keysight Customer Support, on Monday - I replied immediately (they wanted the s/n of the device), nothing since :(
Offline Electro Detective
« Reply #16 on: April 18, 2018, 10:14:44 am »
Test gear and eye candy bling  :-DMM   don't mix   :--
It's unfortunate you had to find out the hard way
« Reply #17 on: April 18, 2018, 10:26:17 am »
You're missing the point - I've been an EE for a very long time (39 years) - and have owned (and still own) a good few DMMs - e.g. I have a trusty Tektronix DMM 916 that I bought probably before some people on this forum were born :) Still works great. I have a stack of Agilent/Keysight test kit (plus a bunch of Tektronix & others) and 99.9% is completely reliable - some of it 20+ years old.
The rather sad, patronizing and snide remarks about bling, eye candy or whatever are irrelevant (and boring) - it's a premium meter from a premium supplier. It should be their problem, not mine.
The following users thanked this post: rsjsouza
« Reply #18 on: April 19, 2018, 10:20:33 am »
I'm not missing any point sir, nor is anyone questioning your qualifications
and I'm ok if you want to defend half baked modern bells and whistles gear when it goes south and bites into your pocket.
You've posted your situation here for a response, so let's see them sort 'their problem' so 'your problem' gets resolved,
without forking out for a new bling meter because the repair or parts cost is almost the same
and most likely if they haven't addressed the issue, you may experience a repeat fading display yet again
Online Fungus
« Reply #19 on: April 19, 2018, 10:38:56 am »
There's nothing to "address", IHMO, that's what OLED screens do.
If they've improved the manufacturing process in any way it will be to make them cheaper or to replace a broken machine with a newer one, not because they think anything is wrong.
« Last Edit: April 19, 2018, 10:58:13 am by Fungus »
« Reply #20 on: April 19, 2018, 10:49:55 am »
Yes my neighbour is having the same trouble with his top end Samsung OLED TV. It's just the tech is shit.
Online Fungus
« Reply #21 on: April 19, 2018, 11:10:27 am »
IIRC those TVs were always aimed at people rich enough to replace them every few years. No TV-techie expected them to last a lifetime.
Keysight/Samsung knew the failure rate and estimated lifetime of their screens when they sourced the parts.
Offline DiddlyJackSquat
  • Country: sg
« Reply #22 on: April 19, 2018, 04:17:14 pm »
Well...
https://www.eevblog.com/forum/testgear/keysight-u1273ax's-oled-screen/
Make that two...
What a piece of shit.
My U2713 (ironically named) monitor has been in use over 4 years usually on for half a day lasted way longer than my U1273AX which wasn't very often used for fear of damaging it...  :palm:
« Last Edit: April 19, 2018, 04:20:25 pm by DiddlyJackSquat »
Offline usagi
« Reply #23 on: April 20, 2018, 06:09:15 am »
oleds are a horrible choice for battery operated test equipment. power hungry and display degrades quickly. avoid ALL oled based test equipment.
« Reply #24 on: April 20, 2018, 08:40:42 am »
You don't have to tell me twice  :phew:
But be advised your common sense comment will attract gangs of infuriated apologists and wallet bitten brand name fanboys,
who think the situation will improve somehow... :-//   and claim we are just being negative and or jealous of their latest thang dud aquisitions
...been there !  :popcorn:
