Author Topic: Agilent/Keysight DSO-X 3034A BLANK NAND Initial Update fail.  (Read 187 times)
Offline RedoineTopic starter
  • Country: ae
Hello Everyone,
I am trying to resuscitate an Agilent/Keysight DSO-X 3034A Scope.
I made the nk.nb0 file from the 3000XSeries.02.35.2013061800.cab file and updated it with YMODEM (loady 0x0361000 115200) and when I type the (go 0x00362000) the process is stuck at the same place :
Here is the log :
U-Boot 2010.03 (Jan 26 2011 - 12:37:34)Agilent P500
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
NAND:  128 MiB
In:    serial
Out:   serial
Err:   serial
SerNum:serial number not programmed
Chip:  BD Board Rev: 4
Net:   smsc
FPGA programming FAILED!
Press space to stop autoboot:  0
p500>
p500>
p500> loady 0x0361000 115200
## Ready for binary (ymodem) download to 0x00361000 at 115200 bps...
CCCancelled
xyzModem - CRC mode, 1(SOH)/0(STX)/3(CAN) packets, 5 retries
## Total Size      = 0x00000000 = 0 Bytes
CCCCCancelled
xyzModem - Cksum mode, 0(SOH)/0(STX)/3(CAN) packets, 10 retries
CCxyzModem - CRC mode, 1(SOH)/19482(STX)/0(CAN) packets, 3 retries
## Total Size      = 0x013064d4 = 19948756 Bytes
p500> go 0x00362000
## Starting application at 0x00362000 ...
Windows CE Kernel for ARM (Thumb Enabled) Built on Jan 24 2013 at 14:52:37
Setting up for a Cold Reboot
Done Setting up for a Cold Reboot
Windows CE Firmware Init
BSP 1.0.0 for the SPEARHEAD600AB board (built Jun 18 2013)
Adaptation performed by ADENEO (c) 2005
+OALIntrInit
-OALIntrInit(rc = 1)
Initialize driver globals Zeros area...
pDrvGlobalArea 0xa0060000  size 0x800 (0xa0060800 -0xa0060000)
Initialize driver globals Zeros area...done
 OALKitlStart
Firmware Init Done.
OALIoctlHalEnterI2cCriticalSection init i2c cs
ERROR: C:\WINCE600\PLATFORM\COMMON\SRC\SOC\STM\SPEARHEAD600\DRIVERS\GPIO\.\sh600_gpio_hw.cpp line 170: GPB driver, RegQueryDword('ISTPriority') failed, status:2
++SER_Init: context Drivers\Active\14
SER_Init, dwIndex:2
SER2 got sysintr:0x00000017
SER2 Serial Port, new baud rate:0x1c200  (UARTCLK:48000000 IBRD:0x1a FBRD:0x2)
OHCI\system.c, GCFG_USBH1_SW_RST
OHCI\system.c, GCFG_USBH2_SW_RST
-EDeviceLoadEeprom 00:30:D3:20:55:FE
Phy found addr 31 (ticks=2601)
WaitForLink Start (ticks=2602)
No Link (ticks=3605)
<--EDeviceInitialize
GMAC DMA status register = 0x0
BALDWIN_DDI: cBaldwinHwIf::Init: Initializing...
BALDWIN_DDI: cBaldwinHwIf::Init: Scope successfully identified.
Is it possible to update this scope with a brand new blank NAND with this method?
Any help here will be appreciated.
Thank you.
