Analog is not a legacy visualisation format. Digital wristwatches came and went. Only a few retro-grouches (Dave?) still wear them.
How many people wear wrist watches these days?
And even an analogue display watch is no longer really analogue. It has a quartz oscillator and digital divider with some digital compensation to improve the accuracy. True analogue watches went out of fashion many decades ago.
Let's not confuse the timekeeping mechanism with the display. And for that anyway the mechanical watch mechanism has an escapment (ie the tick-tock) which flips back and forth to drive the gears in a sequence of discrete movements. But drilling down to such a scale gets us away from the human level and into semantics about just what is analogue and what is digital.
Yes, you are correct and if you look at the speedometer on a car's dashboard, it has a analogue display but the electronics are digital.
Sigh. The question is about analogue meters (e.g. moving needles, or spots of light etc) vs digital meters (e.g. LEDs in the shape of numbers "1.2345", or dekatrons etc). The discussion is not about what is driving the meter. Hence your point, while correct, is irrelevant to the discussion and is (deliberately?) obtuse and confusing.
If you really want to go down your unhelpful path, why don't you just skip to the logical endpoint that "all electronics is digital, in units of one electron (or one photon )".
This is what I tried to point out---there are many "rendered" displays which look like an analog meter face,with the "guts" being digital.
Equally there are displays driven by analog circuitry (or often mechanisms) which display in the form of numbers.
(old type vehicle odometers/trip meters,hour meters,etc).
The discussion should really be on the pros & cons of "pointer type displays" & "numeric displays".
''Bar graph" displays are really a special case of the former,with all its disadvantages & few of its advantages.
And,yes,they can be driven by digital or analog electronics,or even mechanically ---we just see the display!
I haven't used an analog multimeter for decades,but in the main,I have replaced it with an Oscilloscope,rather than a DMM.
Most of the adjustments that are easy to do with an analog meter are equally easy with a 'scope,except of course where the monitored variable is current.
As various people have pointed out,in many cases (& in the overwhelming majority when troubleshooting) great precision is not necessary---most circuitry doesn't really care if your "5volt" rail is 4.8v or 5.2v.
If you need greater precision ,just grab the DMM.
