My vector signal analyzer Anritsu MS2692A:
Brief specs:
- Windows 7 system
- 50Hz-26.5GHz
- 125MHz sampling bandwidth
- Rubidium reference oscillator
- 125MHz-6GHz arbitration vector generator.
I decided to open it for a visual inspection and clean off the dust.
I will note the excellent build quality. Fast, non-glitchy interface, high-end RF characteristics.
I also bought a power meter for it, but it turned out to have a faulty calibration table, more details here:
https://www.eevblog.com/forum/repair/anritsu-ma24106a-repair/msg5853977/#msg5853977Under the shield:
The device is assembled according to the typical layout for this device. All modules are connected to the motherboard. On the left is a pulse power supply.
To the right of the power supply is a computer module (in my case, this is a Core I5 with 8GB RAM).
Next, the ADC module is installed, in my case with a 125MHz capture bandwidth.
I also have a non-working Anritsu MS2690A and several MS2691A that I serviced and repaired. Therefore, the photos will be combined from all devices.
