Author Topic: Anritsu MS2692A teardown (26.5GHz signal analyzer)  (Read 1004 times)
Offline d-elTopic starter
  • Country: ua
« on: August 25, 2025, 04:23:17 pm »
My vector signal analyzer Anritsu MS2692A:
2645719-0
Brief specs:
- Windows 7 system
- 50Hz-26.5GHz
- 125MHz sampling bandwidth
- Rubidium reference oscillator
- 125MHz-6GHz arbitration vector generator.
I decided to open it for a visual inspection and clean off the dust.
I will note the excellent build quality. Fast, non-glitchy interface, high-end RF characteristics.
I also bought a power meter for it, but it turned out to have a faulty calibration table, more details here:
https://www.eevblog.com/forum/repair/anritsu-ma24106a-repair/msg5853977/#msg5853977
Under the shield:
2645723-1
The device is assembled according to the typical layout for this device. All modules are connected to the motherboard. On the left is a pulse power supply.
To the right of the power supply is a computer module (in my case, this is a Core I5 ​​with 8GB RAM).
Next, the ADC module is installed, in my case with a 125MHz capture bandwidth.
2645727-2
I also have a non-working Anritsu MS2690A and several MS2691A that I serviced and repaired. Therefore, the photos will be combined from all devices.
« Last Edit: August 25, 2025, 05:31:30 pm by d-el »
The following users thanked this post: Stray Electron, Doctorandus_P, jjoonathan, syau, TinLethax
  • Country: ua
Re: Anritsu MS2692A teardown (26.5GHz signal analyzer)
« Reply #1 on: August 25, 2025, 04:36:11 pm »
Next,  arbitration vector generator module is installed. It has a solid-state discrete output attenuator.
Photo of the generator from my other Anritsu MS2690A:
2645733-0
Solid-state discrete output attenuator:
2645737-1
« Last Edit: August 25, 2025, 05:02:44 pm by d-el »
  • Country: ua
« Reply #2 on: August 25, 2025, 04:54:35 pm »
Next, the synthesizer module is installed, followed by the YIG driver, Input Attenuator, Input filter, Intermediate filter, Frequency converter.
Photo of this from my other Anritsu MS2690A.
YIG driver:
2645753-0
YIG:
2645757-1
« Last Edit: August 25, 2025, 05:04:14 pm by d-el »
  • Country: ua
« Reply #3 on: August 25, 2025, 04:58:08 pm »
Intermediate Frequency filter and input filter (below):
2645761-0
Assembly:
2645765-1
« Last Edit: August 25, 2025, 05:04:03 pm by d-el »
  • Country: ua
« Reply #4 on: August 25, 2025, 05:05:34 pm »
Frequency converter, side A:
2645779-0
Frequency converter, side B:
2645783-1
« Last Edit: August 25, 2025, 05:16:01 pm by d-el »
  • Country: ua
« Reply #5 on: August 25, 2025, 05:08:59 pm »
Frequency converter, zoomed:
2645789-0
« Last Edit: August 25, 2025, 05:16:15 pm by d-el »
  • Country: ua
« Reply #6 on: August 25, 2025, 05:14:30 pm »
Power Supply, side A:
2645797-0
Power Supply, side B:
2645801-1
« Last Edit: August 25, 2025, 05:16:27 pm by d-el »
  • Country: ua
« Reply #7 on: August 25, 2025, 05:15:42 pm »
Photo of this from my other Anritsu MS2691A.
Input Attenuator:
2645805-0
Online nctnico
« Reply #8 on: August 25, 2025, 05:16:06 pm »
Thanks for sharing!  :-+
Offline TinLethax
  • Country: th
    • TinLethax's messy blog
« Reply #9 on: August 26, 2025, 01:51:19 am »
Thanks for a crisp and clear HD teardown! Always amazed by the RF black magic.
TinLethax! Tek TDS1012, LeCroy WaveJet 324A, Yokogawa DL1740E, Tek A̶F̶G̶3̶1̶0̶2̶C̶ AFG3152C
https://tinlethax.wordpress.com
Offline rvalente
  • Country: br
« Reply #10 on: August 26, 2025, 11:19:55 am »
uow, thats the kind o engineering p*rn I like!
Offline 0837101
  • Country: md
« Reply #11 on: November 28, 2025, 11:04:20 pm »
Hi there!
Can you help me, please? I got a problem with MS2960A.
I brought it from calibration at laboratory, and after power on it doesn't display spectrum of input signal, only noise. It looks like RF input "disconnected" from  analyser.
I try to Auto Calibrate (Cal - SIGANA ALL) - and it's failed. What's happen? is this problem may be caused by transportation? Or may be i should "switch" something in menu?
Thanks and best regards!
  • Country: ua
« Reply #12 on: November 29, 2025, 12:07:47 am »
Was the input signal determined? From a test generator? Can apply deterministic test signal, e.g. 1GHz 0dBm carrier.
Anritsu MS269x have mechanic input attenuator. Some time one or few step is blowed by extra power input signal or mechanic shock. You can manual set attenuator from little to large step by step for check.
If the test signal is not visible against the background noise at all ATT steps, that's a bad sign. Either the YIG has krack or something else has happened.
Offline 0837101
  • Country: md
« Reply #13 on: November 29, 2025, 01:33:14 am »
Thanks for your answer!
Yes, we applied 1GHz from generator. Also we tried to check signal on IF Out on 875/900MHz, but unsuccessfully. I will try your's recomendation!
  • Country: ua
« Reply #14 on: December 10, 2025, 04:49:08 pm »
Check signal after input attenuator, next, after input filter, next, after frequency converter, after IF filter.
I have an almost complete MS2690, I could help with identifying the problem, but there are problems with the delivery of components.
