I got a Fluke 28 II, because it turned out to be a fair bit cheaper than the 87V, and had an IP67 rating to boot. I believe the kit for the 28II may not be as well equipped as the 87V kit is though, but it has your basic thermocouple and probes with crocodile clips included.
Some things I don't like:
- diode function only goes up to 2V which is no good for most LEDs out there and some rectifiers - can be worked around by connecting a diode across a variable current-limited voltage source and measuring DC voltage across the diode, but this is a bit cumbersome.
- current goes to AC by default.
- inconsistent on/off (particularly when the meter decides to turn off on its own, and you have the dial stuck in a range instead of the OFF position).
