Author Topic: Atten ADS 1022CL+ latest firmware  (Read 4089 times)
Offline trisonicTopic starter
« on: September 21, 2018, 09:09:16 am »
Hi
I have an Atten ADS 1022CL+ with:
Software Version: 5.06.02.16
Hardware Version: 11-62-2.6
Could you please tell me what is the latest firmware? Which is the Siglent equivalent firmware scope?
Thanks
« Last Edit: September 21, 2018, 11:08:38 am by trisonic »
Arduino, MODs e DIY: blackstufflabs.com
Offline tv84
  • Country: pt
Re: Atten ADS 1022CL+ latest firmware
« Reply #1 on: September 21, 2018, 04:40:57 pm »
I think it's not here:
https://www.eevblog.com/forum/testgear/siglent-ads-firmware-file-format/msg1364981/#msg1364981
So, show me the latest file you flashed and maybe I can help.
« Reply #2 on: September 21, 2018, 04:44:05 pm »
It's brand "new", i never flash any firmware and gratten don't want to send me the latest firmware because it's an outdated product....
I really don't know where i can find the firmware...
Offline tv84
  • Country: pt
« Reply #3 on: September 21, 2018, 04:55:24 pm »
 :wtf:
You bought a brand new equipment that gratten has as outdated?? ??
Did you use a time-machine?
Insist with them or someone else in the forum might be able to help...
« Reply #4 on: September 21, 2018, 04:59:52 pm »
  :palm:
It's a present and it was the last unsold piece.... but it's my first scope!
 :-BROKE
Offline tv84
  • Country: pt
« Reply #5 on: September 21, 2018, 05:05:56 pm »
Start here:
https://www.eevblog.com/forum/beginners/atten-oscilloscope-firmware/msg180720/#msg180720
Correction:
Looking here
we can see that your Atten is a Prod_ID = 80 and I don't know of any Siglent with that prod_ID.
(Of course the number of Atten FW and old Siglent samples that I possess is limited.)
I only have this one:
ATTEN_ADS1000CL+_V100R003B01D01P31R16.ADS
Product_ID: 80
So, it shouldn't be possible to crossflash to Siglent. I would not risk it without a explicit confirmation from another guy.
BTW, your FW version should be one of the latest.
« Last Edit: September 21, 2018, 05:31:45 pm by tv84 »
Offline rf-loop
« Reply #6 on: September 21, 2018, 05:59:24 pm »
Somehow it looks like Siglent SDS1052DL+  except bandwidth (50MHz)
But I think still most near Siglent model. (exept if someone find Siglent 1022DL+)
Atten 1022CL+ is 25MHz model.
But many basic data match... samplerate, memory... even same display resolution (time ago Siglent rise display resolution in DL/CNL/CML series adding + after model.
SDS1052DL+  is cheap robust "basic school scope".
500MSa/s
7" 800x480 display.   (Older SDS1000DL (example SDS1022DL) and CNL and CML models without + have 7" 480x234 )
32k memory  (but Atten info what I find they have 40k but also who knows if this info is ok)
If some of main things in specs do not match then it is more like not compatible... but who knows..
(in Siglent models only advantage in these some older SDS1000 models is that they can run full  dual timebase with also separate trig for both Ch)
If I remember right there was also in Siglent some older DL 20MHz model..
I have no idea if Siglent SDS1052DL+  FW is compatible with this, Who knows how many changes they do for OEM/ODM products and also Atten can order manufacturing from who ever company if they want cut price from every detail.
Perhaps it is wise to carefully compare your Atten and Siglent user manuals and data sheet and try look what are differences. And also other methods how to detect what it is exactly.
Siglent datasheet and manual can find here for compare.
https://www.siglenteu.com/resources/documents/digital-oscilloscopes/#sds1000dl-series
(when you read look carefully you read right models in documents because they are all in same paper. And not very perfectly informed in every detail what things are not compatible in some model)
guessing was wrong
« Last Edit: September 21, 2018, 11:48:27 pm by rf-loop »
I drive a LEC (low el. consumption) BEV car. Smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Wises must compel the mad barbarians to stop their crimes against humanity. Where have the wises gone?
Offline tv84
  • Country: pt
« Reply #7 on: September 21, 2018, 08:54:05 pm »
rf-loop & all,
Attention: This information is not correct.
As you can easily see in:
https://www.eevblog.com/forum/testgear/siglent-ads-firmware-file-format/msg1335892/#msg1335892
The Siglent SDS1000DL+ is a ARM machine.  I think, it should be the same as the Atten ADS1000DL.
The Atten ADS1000CL+ is a Blackfin machine. I think the CL model was exclusive of Atten (although made by Siglent).
Totally different despite the technical characteristics.
The .LDR extracted from the ATTEN_ADS1000CL+_V100R003B01D01P31R16 FW is attached.
Can be used in:
ADS1102CL+
ADS1062CL+
ADS1042CL+
ADS1022CL+
ADS1152CL+
ADS1202CL+
« Last Edit: September 21, 2018, 10:17:47 pm by tv84 »
The following users thanked this post: rf-loop
« Reply #8 on: September 21, 2018, 09:29:42 pm »
Can be used in:
ADS1102CL+
ADS1062CL+
ADS1042CL+
ADS1022CL+
ADS1152CL+
ADS1202CL+
Thanks for the information.
What is the purpose of the ldr file? Is the firmware to flash with the USB stick?
Thanks
Inviato dal mio ONEPLUS A5010 utilizzando Tapatalk
Offline tv84
  • Country: pt
« Reply #9 on: September 21, 2018, 09:49:21 pm »
The Blackfin Loader File (.LDR) is the the binary file that contains all the memory blocks that must be loaded into the proc memory plus information about its start address, etc.
(it is extratect from the Siglent encrypted/compressed .ADS file.)
See: http://www.dolomitics.com/downloads/ldrviewer.html
« Reply #10 on: September 21, 2018, 10:07:53 pm »
and where i can find the ATTEN_ADS1000CL+_V100R003B01D01P31R16 firmware?
Offline tv84
  • Country: pt
« Reply #11 on: September 21, 2018, 10:26:38 pm »
Here.
Remember this is v3.01.01.31R16.
« Reply #12 on: September 21, 2018, 10:33:19 pm »
Here.
...is this firmware older than mine?
Offline attenchina
  • Country: cn
« Reply #13 on: September 30, 2018, 01:42:20 am »
I KNOW THAT, IT IS MADE IN cHINA
http://www.atten.com
Atten soldering iron manufacturer
« Reply #14 on: September 30, 2018, 09:03:31 am »
Online snickers
    • RF Electronics
« Reply #15 on: February 19, 2019, 04:10:52 am »
Hello guys.
Can anybody tell me the model of IC ADC in ATTEN ADS 1000 ?
In my is only two and I need to buy and solder the third.
SQ5DBF, 73!
Online snickers
    • RF Electronics
« Reply #16 on: March 07, 2019, 10:08:36 pm »
Some experiments with my old stuff.
« Last Edit: March 07, 2019, 10:15:50 pm by snickers »
SQ5DBF, 73!
