Hi
I have an Atten ADS 1022CL+ with:
Software Version: 5.06.02.16
Hardware Version: 11-62-2.6
Could you please tell me what is the latest firmware? Which is the Siglent equivalent firmware scope?
Thanks
It's brand "new", i never flash any firmware and gratten don't want to send me the latest firmware because it's an outdated product....
I really don't know where i can find the firmware...
You bought a brand new equipment that gratten has as outdated?? ??
Did you use a time-machine?
Insist with them or someone else in the forum might be able to help...
It's a present and it was the last unsold piece.... but it's my first scope!
Somehow it looks like Siglent SDS1052DL+ except bandwidth (50MHz)
But I think still most near Siglent model. (exept if someone find Siglent 1022DL+)
Atten 1022CL+ is 25MHz model.
rf-loop & all,
Attention: This information is not correct.As you can easily see in:
https://www.eevblog.com/forum/testgear/siglent-ads-firmware-file-format/msg1335892/#msg1335892The
Siglent SDS1000DL+ is a ARM machine. I think, it should be the same as the
Atten ADS1000DL.
The
Atten ADS1000CL+ is a Blackfin machine. I think the CL model was exclusive of Atten (although made by Siglent).
Totally different despite the technical characteristics.
The .LDR extracted from the ATTEN_ADS1000CL+_V100R003B01D01P31R16 FW is attached.
Can be used in:
ADS1102CL+
ADS1062CL+
ADS1042CL+
ADS1022CL+
ADS1152CL+
ADS1202CL+
Can be used in:
ADS1102CL+
ADS1062CL+
ADS1042CL+
ADS1022CL+
ADS1152CL+
ADS1202CL+
Thanks for the information.
What is the purpose of the ldr file? Is the firmware to flash with the USB stick?
Thanks
Inviato dal mio ONEPLUS A5010 utilizzando Tapatalk
The Blackfin Loader File (.LDR) is the the binary file that contains all the memory blocks that must be loaded into the proc memory plus information about its start address, etc.
(it is extratect from the Siglent encrypted/compressed .ADS file.)
See:
http://www.dolomitics.com/downloads/ldrviewer.html
See: http://www.dolomitics.com/downloads/ldrviewer.html
and where i can find the ATTEN_ADS1000CL+_V100R003B01D01P31R16 firmware?
Here.
Remember this is v3.01.01.31R16.
Here.
...is this firmware older than mine?
I KNOW THAT, IT IS MADE IN cHINA
Hello guys.
Can anybody tell me the model of IC ADC in ATTEN ADS 1000 ?
In my is only two and I need to buy and solder the third.
Some experiments with my old stuff.
