Author Topic: Atten ADS1152CM firmware request  (Read 3531 times)
Offline fpgaarcadeTopic starter
« on: August 15, 2016, 09:17:24 am »
Hi all.
(I hope this is the right place to post this, apologies if not).
I picked up an Atten ADS1152CM 'scope in Shenzhen two years ago. It was a reasonable price for a 150MHz model.
Sadly no firmware updates ever appeared on Atten's website, and it had a number of operational glitches which made it very painful to use.
Looks like gratten.eu is the place to go for some Atten kit, but there are no 'scopes listed now. It looks like the 'scopes are now branded by Siglent?
I foolishly reflashed it with the firmware for the Siglent SDS1152CML, with the assumption it would check if the firmware was compatible.
It didn't. Although the 'scope still works, the screen position is offset horizontally and the menu is not visible.
I've contacted Atten through a Chinese colleague (no response from English email), and they have been "unable to locate the correct firmware" and consider the 'scope "very old" after two years.
I find this lack of firmware updates very frustrating.
Does anybody have, or know where to look for, the correct firmware?
Many thanks,
Mike
Offline kasskon
  • Country: gr
Re: Atten ADS1152CM firmware request
« Reply #1 on: April 19, 2020, 06:58:23 am »
hey i had the same problem did you have  the old firmware?
Offline tv84
  • Country: pt
« Reply #2 on: April 19, 2020, 10:08:19 am »
Ask member tautech which is Siglent's most appropriate FW and the we can try from there.
I think all the FWs that I've seen have the larger display...
The following users thanked this post: kasskon
« Reply #3 on: April 20, 2020, 03:47:49 am »
Sorry no 5" display model FW at all, only for 7" displays. (**L models)
Avid Rabid Hobbyist
Offline tv84
  • Country: pt
« Reply #4 on: April 20, 2020, 08:44:57 am »
Another option is to flash the Atten FW once again.
But I never saw a Atten CM FW also.
« Reply #5 on: April 20, 2020, 08:51:08 am »
Another option is to flash the Atten FW again.
I have:
ATTEN_ADS1000CML_V100R003B01D01P31R16.ADS
ATTEN_ADS1202CML_v2.06.02.15R1.ADS
Yeah but the OP is about the CM, a 5" display not CML with 7" display so if kasskon has the 5" CM model those FW's might not work.
I never handled any CM models only CN for which I never had FW and then the **L models came along ........
Avid Rabid Hobbyist
Offline kasskon
  • Country: gr
« Reply #6 on: April 20, 2020, 02:11:50 pm »
i don't know if its possible to edit the Siglent SDS1152CML firmware and change the display from 7'' to 5,7" :-/O
Offline tv84
  • Country: pt
« Reply #7 on: April 20, 2020, 02:55:39 pm »
Just with the source code.  :)
« Reply #8 on: March 23, 2023, 06:37:04 pm »
Just bring this thread back from the dead...
I got some firmware from Siglent which partially worked but the display was (more) corrupted.
I tried to revert and bricked the device.
I got cross with it and, well let's just say I now own a Tek....
Offline tv84
  • Country: pt
« Reply #9 on: March 23, 2023, 09:54:06 pm »
Please share it.
Offline coromonadalix
« Reply #10 on: March 24, 2023, 01:33:32 am »
or maybe here with translation, they have support ?
https://masteram.com.ua/uk/digital-storage-oscilloscope-atten-ads1022c/
« Reply #11 on: March 24, 2023, 11:19:43 pm »
sorry this was a while back now. I looked at my archives but I can't find it.
As I said, the display was unusable with it so it wasn't a solution. I moved on.
/Mike
