I have recently acquired a Keysight audio analyzer with 2 input channels and 2 output channels.
One of its behaviors is interesting, that the 4 channel combinations (TX1-RX1, TX1-RX2, TX2-RX1, TX2-RX2) have different performances.
At the same condition (1kHz tone, 192ksps, 131072pts FFT, differential out-differential in, 50R output impedance, 50R BNC cable, 1MR input impedance, 1Vpk output, 1Vmax input range):
TX1-RX1: -111dB THD+N, -120dB THD
TX1-RX2: -110dB THD+N, -115dB THD
TX2-RX1: -110dB THD+N, -118dB THD
TX2-RX2: -108dB THD+N, -111dB THD
Background noise is -111dB, so calculated THD+N (-108dB, -110dB, -110dB, -110dB) values match measured THD+N values.
What I don't understand is the correlation between the four combinations.
TX1-RX1 is only 2db different from TX2-RX1, which means TX1 is only 2dB better than TX2.
However, TX1-RX2 is 4dB better than TX2-RX2, why is that?
Another thing to mention is input level sensitivity. RX2 is 5dB worse than RX1 at full scale, but it 1dB better at lower amplitude, peaking at -121dB, while RX1 is very stable in THD, constant at -120dB (both with TX1 generator).
Can any audio gurus explain why is this? Can it be from ADC/DAC individual error or can it be from layout?
The analog circuit and layout are both symmetric, but the clock is not. The clock buffer is closest to RX1 ADC, then RX2 ADC, then TX1 DAC, and lastly, TX2 DAC. Will that play a role?
The clock signal is 50R series terminated on die (5PB1106), but the traces don't look like 50R. The top side traces look like 100R width, but I can't be sure since I don't know the exact stack up of the PCB, nor I know the internal layer trace thickness.
I need help form the forum on why is it. If it is a design issue (like as I said, a clock issue, but that doesn't make sense as low level performance of RX2 is better than RX1), then I will have to return it before I do any reworks on this very expensive board. If this is an individual issue, then I will relinquish the warranty and solder a binned ADC in place of RX2 ADC.
Lastly, as usual, Keysight always ships some flawed products to me. This time this card came with two stripped screws and one of them protrudes from PXI bracket and scratched my M9111A.
That's certainly not what I expected as a "prime condition" used demo unit straight from KS.
