I need one for one-off use, so didn't feel too guilty about buying a clone. It worked fine.
If its anything like the Keil u-Link clones you will have no static protection on the USB side and reduced static protection the device side!
So okay to use if you observe static handling precautions and likely to fail quickly if you dont!
