Author Topic: AWG Amplifiers  (Read 3302 times)
bartdinger
  • Guest
AWG Amplifiers
« on: June 23, 2015, 08:22:09 am »
Does anybody have any recommendations for a waveform generator amplifier? Most AWGs (built into oscilloscopes at least) seem to only have fairly low signal level outputs, but I have on occasion needed to be able to replay a stored signal at the original signal levels with either decent current drive or higher voltages. About the only reasonably priced thing I've found is a Rigol PA1011, most other solutions seem to cost a fortune, or should I say more than I would be prepared to spend on a piece of gear I wouldn't use often. I don't own I rogol scope, but it looks like this amp can be setup via usb and used with anything. Anybody have an experience with this or other amplifiers?
« Last Edit: June 23, 2015, 08:34:48 am by bartdinger »
Re: AWG Amplifiers
« Reply #1 on: June 23, 2015, 10:14:24 am »
Recently added new Siglent AWG power amp
http://siglentamerica.com/prodcut-fjxx.aspx?fjid=1289&id=-1&tid=16&T=1
RRP USD389 plus taxes if any
Avid Rabid Hobbyist
Offline w2aew
    • My YouTube Channel
Re: AWG Amplifiers
« Reply #2 on: June 23, 2015, 01:18:41 pm »
What peak-peak voltage levels are you looking for?
FAE for Tektronix
bartdinger
  • Guest
Re: AWG Amplifiers
« Reply #3 on: June 23, 2015, 10:16:00 pm »
15V p-p would be perfect.
That Siglent thing looks like it would suit my needs perfectly. Thanks :)
Offline Lightages
  • Canadian po
Re: AWG Amplifiers
« Reply #4 on: June 23, 2015, 11:08:14 pm »
I have a couple of questions.
#1. It has an input impedance of 15kohms. That means you might need to use a 50ohm pass through terminator if you want waveform fidelity when coming from the waveform generator. Why would they not include this simple thing as a selectable input impedance?
#2. It also has a very low output impedance, again no 50ohm selectable.
The output impedance of the instrument Zo is less than 2?,
and the range of output voltage is -13V ~ +13V(RL=1K?).
What are the implications for using this where a 50ohm source is preferred?
And one point to consider; its bandwidth is only 1MHz.
