Author Topic: Bench DMM Noise & Stability Comparisons with TestController  (Read 33012 times)
Online KungFuJoshTopic starter
  • TEAS is real.
Re: Bench DMM Noise & Stability Comparisons with TestController
« Reply #350 on: September 20, 2026, 03:04:32 am »
Josh can comment on this, but how much luck (if any) have you had with using batteries and hotplugging? I am still weary after what I think Josh did which was kill one of my rev1 units with hotplugging.
Hot-plugging wasn't the issue. The first unit wasn't labeled at all, so I connected the wrong side to power (ref output connected to PSU). :palm:
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
Offline Martin72
« Reply #351 on: September 20, 2026, 11:23:56 am »
It's not going to work today...
I did a quick test yesterday after setting it up, and the 10V was there.
I tried the same thing again a little while ago—no output voltage.
I didn't touch anything; everything was left just as it was yesterday—I just closed the circuit.
Then I opened up the reference—and smoke came billowing out at me...
The IC “U1” is fried....
I don't know the circuit diagram, but it seems to have something to do with the input.
What a bummer.
Offline Martin72
« Reply #352 on: September 20, 2026, 12:41:08 pm »
The test will continue; I set the internal jumper for the reference to 15Vext and then reset the reference.
We should discuss further details about the defect that occurred there:
https://www.eevblog.com/forum/projects/udr1399-adr1399-based-10v-reference-module/msg6362832/#msg6362832
Offline TylerPeppy
  • I build things. I break them too.
« Reply #353 on: September 20, 2026, 01:28:47 pm »
I have already commented on the failure on my thread, have a read. A simple 2-component mod can help fix this, sorry that your unit was killed, but the 15V_EXT was added for a situation where the LDO wouldn't work properly.
Well it didn't do that when I tested it...
Offline Martin72
« Reply #354 on: September 20, 2026, 04:45:11 pm »
So, a one-hour recording of the “Tyler Reference” is now in the can.
Due to a few setup issues, you can see a reference that has already gone through over an hour of warm-up.
From the moment I turned it on until it stabilized, I had a minor glitch in the TC setup, but I can say that stabilization takes about 15 minutes. ;)
After that, I let it run for an hour—and then noticed that the DMM7510 was missing a decimal place... So I ran it for another hour.
See the image for the result.
Settings:
10 PLC
Auto-Zero On
Martin
Edit: Roomtemp 22.1C°, Humidity 50%
« Last Edit: September 20, 2026, 04:48:00 pm by Martin72 »
The following users thanked this post: KungFuJosh, TylerPeppy
  • TEAS is real.
« Reply #355 on: September 20, 2026, 06:35:28 pm »
Can you do a test with 100NPLC on the Siglent, and 10NPLC x 10 Filter on the Keithley?
Thanks,
Josh
Offline Martin72
« Reply #356 on: September 20, 2026, 07:04:28 pm »
Yes, but not today...
In the next few days, promised.
Offline TylerPeppy
« Reply #357 on: September 21, 2026, 12:14:04 am »
Settings:
10 PLC
Auto-Zero On
Martin
Stabilisation time seems to match what I had more or less, was 14 - 16min when I conducted some tests.
Tyler
