Author Topic: best cheapest electronics fluke  (Read 18041 times)
Offline thomst77Topic starter
« on: June 25, 2013, 03:17:21 am »
Currently I only have a $20 Radio Shack pocket multimeter. I have had it for 20yrs. It has been a good meter but it is very basic. I also have a $5 Harbor Freight CenTech very cheap meter, But it was all I could afford. I have been getting more into building circuits and kits so I need something more geared towards electronics. I have been looking for a moderately priced meter and I have around $150 to spend. I have been looking hard at the BK Precision 2709B multimeter. But I would really love to have a Fluke. So my question is what is the lowest priced Fluke that would be geared more towards electronics? It has to have the full capacitance and resistance range that I would need for electronics work. Be able to test leds. I have looked at the 100 series and I am not sure it has the ranges I need? I appreciate everyones input on which one I should get.
Tom
Offline Stonent
Re: best cheapest electronics fluke
« Reply #1 on: June 25, 2013, 03:33:16 am »
Have you watched these two videos yet?
It may help with your decisions
Offline Lightages
  • Canadian po
« Reply #2 on: June 25, 2013, 03:57:36 am »
The short answer is the Fluke 17B. I think that would be much happier with the 2709B, or a Brymen BM257 from iloveelectronics here on the forums.
Offline Stonent
« Reply #3 on: June 25, 2013, 03:59:09 am »
I found this selector, it might help
http://www.fluke.com/fluke/usen/products/ProdSelGuide-DMM.htm
To just get the 100 series, select Compact.
You can get a higher capacitor range in the 100 series but the 17B looks pretty good if you only need up to 100uF.
Are you wanting the Fluke for the quality or the prestige?
« Last Edit: June 25, 2013, 04:09:45 am by Stonent »
Offline Lightages
  • Canadian po
« Reply #4 on: June 25, 2013, 04:10:24 am »
The 100 series does not have microamps which is pretty necessary for electronics. Almost no one needs big capacitor measurements.
Offline Stonent
« Reply #5 on: June 25, 2013, 04:15:24 am »
Well, there you go, sounds like that would be the best over-all match for you from Fluke.
Offline retiredcaps
« Reply #6 on: June 25, 2013, 04:31:22 am »
It sounds like you are in the USA.  If you don't mind buying used, you can get a Fluke 87V with patience either on ebay or locally.  If you don't have patience, you can quite easily get a Fluke 87 III for under $150 USD.  If you aren't a very good shopper, then you can easily get an original Fluke 87 for $150!  :-DD
For example,
http://www.ebay.com/itm/321147901867
Obviously, there are caveats with buying used, but you can get a good deal.
Getting a Fluke 87V for $80 USD + free shipping takes a lot of luck.
http://www.ebay.com/itm/121127464902
Offline Lightages
  • Canadian po
« Reply #7 on: June 25, 2013, 04:32:36 am »
But really, I have to push the Brymen BM257 for $135 shipped to your door. It out classes the Fluke 17B in every way except for the Fluke reputation. IMHO it is the best meter you can buy for under $150. And then should you want or need it you can also get the PC connection for it.
Offline madshaman
  • ego trans insani
« Reply #8 on: June 25, 2013, 04:44:52 am »
+1
To be responsible, but never to let fear stop the imagination.
Offline cthree
« Reply #9 on: June 25, 2013, 04:54:13 am »
You can buy a Fluke 87III on eBay for $99 all day long. I bought 2 of them in the last couple months. You can get a 87V for under $200. What the III doesn't have that the V does is support for temperature and low pass filter. The III is a way better value and will crush any of those sub $99 meters (literally, the thing is a brick!)
Offline retiredcaps
« Reply #10 on: June 25, 2013, 05:40:29 am »
A few other operational differences between the III and V.
III measures up to 5uF, one level backlight, defaults to DC for current measurements, 4000 count, hi-res 20,000 count is only 1 update/sec, getting into hi-res "reboot/reset" the entire meter.
V measures up to 9999uF, two level backlight, defaults to AC for current measurements, 6000 count, hi-res 20,000 count is 4 updates/sec, getting into hi-res does NOT "reboot/reset" the entire meter.
« Reply #11 on: June 25, 2013, 05:52:44 am »
Thank You all for the input. I do want Fluke for the Quality and Reputation. But the Brymen looks nice. I know the Taiwanese make good stuff. Better than China in my opinion. And the 17b Fluke is Chinese built. As for the Used Fluke 87. I would really like to have one of those. I just don't like buying used on ebay. What do you think about the 100 series Flukes? Which one would be more geared for Electronics? And where can I order the Brymen?
Offline iloveelectronics
  • Country: hk
« Reply #12 on: June 25, 2013, 06:45:56 am »
I have a few more Brymen BM-257's available in my eBay store (link in my signature). I can also offer a discount if the sale takes place outside of the eBay system, as the eBay fees are saved that way. There are quite a few members here who are my customers and hopefully that will give you some confidence even though I'm not a big corporate seller.
I actually have a few BM-521, 525 and 869 in stock too. They will be posted on my store soon.
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
Offline madshaman
  • ego trans insani
« Reply #13 on: June 25, 2013, 06:48:37 am »
I got my Brymen 867s here: http://www.tme.eu/pl/
Another thing about actual Brymen (as opposed rebrands) stuff, is the price (imho) is *amazing*.
I'm in Canada and *with shipping*, I probably saved $550 ordering an original Brymen from Poland including shipping as opposed to locally available equivalents or rebrands.  (I bought two BM867s and two KITBU-86X connectivity cables and software, which are *reasonably* priced compared to rebrands, not $150+ or something similarly outrageous).
I'll give you an idea of how cheap: I paid 169 USD per BM867.  Total shipping cost: 23 USD.
$200 to the door for that much meter is fantastic.
Just my two cents, ymmv.
« Reply #14 on: June 25, 2013, 07:12:37 am »
Thank You all for the input and the very fast replies. It is a nice community here. I really like Dave's videos on youtube. That is how I found this place. I think I have decided on the Brymen.
Thanks Tom
Offline Lightages
  • Canadian po
« Reply #15 on: June 25, 2013, 02:32:34 pm »
You will not regret it. And you can trust iloveelectronics. He is a very trustworthy and helpful person.
Offline calin
« Reply #16 on: June 25, 2013, 06:10:44 pm »
Brymen is good no question.. maybe a bit of overkill but if you really want the digits/count go for it. Sincerely I would go for two (yeah you want to measure amps and volts @ the same time trust me)  UT61E-s  at around 50-60$.
As for 87-V - stay with the eyes open on craigslist .. I got an 87 V at 100$ from Craigslist .. beauty.
Offline Lightages
  • Canadian po
« Reply #17 on: June 25, 2013, 07:50:30 pm »
Yes I agree that the UT61E is still a good buy too, except for the lack light, temperature, auto-power off, burden voltage and input protection. It has higher counts and basic accuracy plus included PC connection.
The OP already stated that he had another meter so the best thing to do is get much better meter. If one needs a second meter after getting a BM257 then a Uni-T UT136B, Digitek DT2843R, or a Digitek DT-4000ZC would be good cheap second meters. They each have their benefits.
« Last Edit: June 25, 2013, 07:55:12 pm by Lightages »
Offline Lightages
  • Canadian po
« Reply #18 on: June 25, 2013, 08:01:22 pm »
I just remembered that one of the requirements was that the new meter is able to light LEDs. I will not be home for 3 more days so I can't double check my BM257. If I remember correctly, it can't do so. Can anyone else confirm before then?
This has never been important to me so it doesn't stick in my mind.
  • Country: hk
« Reply #19 on: June 25, 2013, 11:14:49 pm »
I just tested. The diode mode of the BM-257 only puts out about 1.55V, which can barely light up a red LED if you look carefully, but no reading on the display. It cannot light any other colour LEDs.
« Last Edit: June 26, 2013, 02:29:04 am by iloveelectronics »
« Reply #20 on: June 26, 2013, 12:53:19 am »
I just tested. The diode mode of the BM-257 only puts out about 1.55V, which can barely lit up a red LED if you look carefully, but no reading on the display. It cannot lit any other colour LEDs.
That is not a critical point. I can test leds other ways if need be.
Offline Robomeds
« Reply #21 on: June 26, 2013, 04:15:28 am »
I have just a few thoughts to add.  First, I have had good luck with Ebay and would suggest you give it a chance.  I recently bought a Fluke 87-3 for $80 off ebay (it was the Matco branded version).
A few others you might consider are the Agilent U1241.  I got one recently and the only down side is the speaker is very quite.  The specs are very good and certainly for most measurements this is just as good as the Fluke 87.  A forum member also figured out how to hack it into a U1242.
http://www.ebay.com/itm/NEW-Agilent-Technologies-U1241AN-True-RMS-Digital-Multimeter-/251294414259?pt=LH_DefaultDomain_0&hash=item3a825075b3
Another good fluke alternative is the series of BK Precision meters made by Metrix a while back.  This is the same one I have (not the exact unit).   The BK 5360 (and the 53x0 family) are rebadges of the Metrix MX line.  The 5360 is the bottom of the range with a lousy 0.1% accuracy and a 50,000 count display.  It also has AC+DC true RMS and just in case your bench gets flooded, it's IP677 rated which means you can submerge it if you want.  Note that you should NOT test high voltage lines when you are submerged.  Anyway, for $41 this buyer got a meter that would give the Fluke 87 a good run for it's money.  This however is a used meter with the associated risks and the like.  It's also made in France... if you want to pick on a European country, why not pick France ( :D )
http://www.ebay.com/itm/BK-Precision-Digital-Multimeter-5360-/281096537476?pt=LH_DefaultDomain_0&hash=item4172a8c584
One last meter to consider would be the Fluke 27.  Dave's got a review.  Again they are ebay so I will understand if you pass.  However, they are accurate, have uA readings, and can be had really cheap if you look around.  Mine cost only $16 (without probes).
« Last Edit: June 26, 2013, 04:18:10 am by Robomeds »
Offline EEVblog
« Reply #22 on: June 26, 2013, 05:16:43 am »
Yeah, you won't get a new Fluke for your price range, unless it's the 17B from China.
Used Flukes are generally a very good and relatively safe option though.
Offline Stonent
« Reply #23 on: June 26, 2013, 05:27:20 am »
Well Amprobe, Keithly, Fluke, Matco, and Tek are all owned by Danaher corp... Any of those brands have good quality instruments and tools. And I'm sure they all have some overlapping product lines so you could get a Fluke under another name easily.
Offline Robomeds
« Reply #24 on: June 26, 2013, 12:31:28 pm »
You can get a Matco cobranded Fluke  but other than the rare Sears Craftsman that was a rebadged Fluke 17B, I'm not aware of any Flukes that were rebadged as something else.  Based on Dave's reviews I wouldn't assume an Amprobe is a Fluke under the skin.
