The Amprobe AM-530 is quite on par with the 179 as well ...
Sorry for disagreeing on this.
The AM-530 is a crap! The auto power off can't be disabled, and the meter turns off after 15 minutes, even if you are using it, and can't be disabled. It's very slow, specially when reading capacitors, and the one I have at work has having issues lately, with random readings that goes away if turned off and back on again. I wouldn't recommend this meter to anyone.
The Amprobe AMP-220 clamp meter that I also have at work, I'm very pleased with, so it's not a brand thing.
I don't know about the other 500 series Amprobe meters, but that particular model is disappointing.
The Fluke 179... I also have one, but don't think I have to say something on it's behalf.
PS: The AM-530 wont turn auto-power-off when MAX/MIN button is pressed, but
in recording mode it will only show the MAX or Min value, so it doesn't keep track of the average value, neither show the actual value being measured. This is the worst implementation of a recording feature I ever came across
