Might learn something trying to repair them...
At work, my boss got 3 dead Leader 'scopes locally for $20 each and we have spent a few bored moments fixing them. We had not quite the right manual to start with which made for some entertainment where the manual called for 100V on one power supply, but this version was only 80V... and the rail was down. It turned out all I had to do was ask - Leader emailed me the correct service manual within a day of asking about it!
The fixes were mostly in the low voltage power supplies. Dead bridge rectifiers, a dead 7912 and a couple of dead transistors, a previous bad repair of a trace (probably broken replacing one of the voltage regs/power transistors). Finally, one had a dead transistor in the vertical final amplifier. All parts could be sourced locally as NTE equivalents, some even at Radio Shack! All that's left is to properly clean the range switches and we'll have a couple of good 50MHz 'scopes. The third doesn't have a case and is definitely a spares unit. Economical repair? Not if we charged for our time, but that wasn't the point.
