Ooh I somehow missed this thread, and it's very much up my street. And I see now it was started by a vaper, awesome
Vaping is my current hobby and passion - @BillW50, look for me on ECF if you want to discuss a lot more about accurate Temp Control and the technical stuff that goes with it, such as accurate ohms reading, adjusting for Static Resistance in the atomizer/510s, and adjusting TCRs to vape with different wires. My main thread on the subject at ECF is here:
TC beyond Ni200: Nickel Purity, Dicodes; Ti, SS, Resistherm NiFe30; Coefficient of ResistanceAnyway, back to the topic at hand - to answer your original question Bill, I have already bought two of the very device you are asking about (and for the same reason - vaping!) :
(Click on any of the images in this post to see them larger)I also bought two high quality current sense resistors so I could validate their accuracy, and the accuracy of other ohm readers I have or might get. As you can see, on the left I have a 0.01 ohm resistor with +/- 0.25% tolerance, and on the right it's 0.1 ohm with +/- 0.1%. (I bought these resistors from eBay - they're used, having been taken out of a military-spec current meter.)
And according to these readings, these micro ohm readers are accurate at least for these resistance ranges - both are reading within the tolerances of the resistors. I have some 0.001 ohm 1% resistors on order from eBay so I can do further verification at the milli-ohm level; would like to get some 0.001 ohm 0.5% or 0.1% as well if I can find some that are affordable.
I don't believe that they're actually accurate to micro ohm or that close to it. For certain they're not accurate to six decimals, because the last digit always fluctuates. The fifth digit was fairly stable for these readings, but does sometimes move about a bit.
I'm generally happy to regard them as definitely accurate to milli-ohm, and at most accurate to 0.1 milli-ohm; 4 digits, 1-in-10,000. That's certainly good enough for me.
I checked out the current they put out, as my (beginner's) reading on micro-ohm/milli-ohm readers (in particular
this document from Megger about low-ohm reading) suggested that the current used by the reader was very important for the accuracy?
In that sense, it's good news/bad news for these micro ohm readers:
0.101 A or 84mA - but I'm not sure why I get different readings depending on whether I'm in A or mA mode on the DMM? Surely 0.101A should show 101 mA or 85mA should show 0.085A? Not quite sure what's going on there?
Anyway, I believe this is pretty good news because it's way more than the average DMM ohm reader sends - which is usually about 1 or 2mA I believe? But it's bad news because it's nowhere near the multiple-amps that a true micro ohm reader sends. (Though in this case, it made me realise that probably, for my vaping purposes, I would never want a true micro-ohm reader - I can't send 10A of current through the wires I would be testing!)
Finally, here's a look inside:
They use a 3.7V Lipo battery, hard wired to the board. I have been thinking about replacing this with a battery socket. It's great that it uses 3.7V as I could use any standard 18650 battery, of which I have loads (again, for vaping.) For some reason, I got very different battery capacities in my two models!
The PCB is quite simple. I'd be very grateful for anyone's comments on how this is designed and how it does the calculations? I would really like to make my own reader, and that's one reason I bought the second of these - so I could have one to play about with and maybe change components.
The chip in the middle is the
ADS1232 24-bit ADC. To the left of that, the smaller chip is the
STM32F030F4P6 - a 32bit 16kb microcontroller, which presumably does the calculations.
I'd really like to build one of my own, doing the calcs on an Arduino. It'd be a fun project.
Though I just saw in this thread that someone has linked to a plan for a micro-ohm reader, so I'll be studying that first!
Anyway, in conclusion I think these devices are pretty great considering I paid £35 per device ($50) on eBay. I am very confident that they are definitely accurate at least to three digit / milli-ohm, and quite possibly even to 4 digits. This is more than good enough for my purposes, and it's very awesome not having to worry about the contact resistance / resistance in the cabling.
My next plans are to:
1. On one, put on better quality cables with stronger clips, so it's easier to grab onto wires/resistors to test. This is easy to do as they come with a 4-wire screw terminal block.
2. On the other, mod the case to put in a vaping 510 connection, so I can directly screw down an atomizer onto the reader and get a super accurate reading for it; in other words, a home-made 4-wire micro-ohm version of the ELeaf type reader!
I'm hoping this will work out OK as a 4-wire reader if I simply solder two wires onto the positive and two on the negative? I might need to get them in appropriate positions and/or alignments - that Megger guide I linked earlier has some discussion of that. Worst case, I'll simply re-create the clips, with permanent clips onto the positive/negative rather than soldering the wires directly.
PS. Bill, throw that ELeaf reader in the bin. It is known to be not worth the plastic it's made out of. I made the mistake of buying one too. Utterly useless if you want a figure close to accurate. Inside is a hot glue mess with crappy wiring, and it doesn't even have a proper 510 connector.
I started out using my DMM as a reader, because it can do two decimal places. So before I got the YZKStudio devices, I was measuring atomizer resistance like this:
That's a Fat Daddy Vapes v3 Shorty 510, connected to two 4mm banana plugs to plug into the DMM. Worked well! That's the sort of socket I plan to put on one of the YZXStudio readers, which will then become my standard vaping ohms reader once I've done it.
