Looking for a 500MHz scopes and I'm willing to repair either one.
Studied both models specs and both are very similar.
HP 54542A might need battery backed cell replaced based on the issue symptoms only that calibration failed.
Lecroy 9354TM might need more work, passes internal tests and calibration except channel 3 input is not generating signal.
And slow to respond to button inputs. CRT has burned in where lines and text had been there for long time but still usable.
Seller's description says:
"The unit passed POST, self test, internal calibration & diagnostics. Performed verification test and passed (but not all done due to lack of matching equipment). Being sold for parts due to CH 3 Input not working (doesn't generate any input signals, all other channels are working). And, the unit responds time very slow. There is a delay of 5 to 10 seconds before any input commands shows up on the display screen. "
Had tried to search here and internet searches related to repair or mods on this Lecroy 9354TM and I came up nothing. Hopefully anyone knows these could respond.
Lecroy has several sub models for the 9354 including 9354A.
Thanks for your responses.
Cheers,
