Hello,
Recently I was looking at getting a lower-cost high current AC/DC probe. I found Pico's TA167, R&S's HZO51, or I could use an older Tek current probe and their CT-4 adapter.
I can't seem to find any derating info for either the Pico or R&S's probes. The manuals are rather sparse in terms of graphs. Are they not based on a coil that needs derating?
Tek's CT-4 is very very detailed. But how do I power the DC Bucking Coil? Like, they give a voltage/amperage, but that's spec'd per DC amp and I have no clue how to power the DC Bucking Coil with the appropriate frequency/amplitude DC value so that I get the correct response for DC current. Although their older probes can measure DC current, is the CT-4 designed to only measure AC current?
Thanks!
PS: When I say "DC current" I'm referring to pulsed DC. I'm not planning on using an oscilloscope to measure continuous DC current. I'd use a clamp meter for that.
