Author Topic: Choosing the right multimeter  (Read 6498 times)
Offline ulaciTopic starter
  • Country: hu
« on: February 10, 2019, 10:25:16 am »
I'm trying to choose between 2 digital multimeters in the 100-120€ range that are sold in Europe.
1. UNI-T UT71B   http://www.uni-trend.com/index.php?m=content&c=index&a=show&catid=182&id=207
2. Brymen BM257s   https://brymen.eu/shop/bm257s/
I'm an electrical engineering student, I would like to use it for a long period, so I need a reliable one. I have seen the comparison videos, where there is much attention to high voltage protection, drop test, waterproofness, etc., which I don't need (I can care about my stuff and I'm not going to use it for electricians work). What is important for me is:
  • precision, accuracy
  • long-term properties (drift, failure)
  • measurement ranges, bandwith
  • any other things you have experienced that can be important
So which one do you recommend for general electrical engineering? (or some other series from these vendors)
Offline Fungus
Re: Choosing the right multimeter
« Reply #1 on: February 10, 2019, 10:31:22 am »
Brymen!
Offline 2N3055
  • Country: hr
« Reply #2 on: February 10, 2019, 12:18:18 pm »
Brymen BM257 is excellent meter, in Fluke class.  Can't go wrong.
Dr. Richard W. Hamming
Offline Cnoob
« Reply #3 on: February 10, 2019, 01:54:51 pm »
The Bryman BM257s is my go to meter, if I want to take a quick voltage reading, buzzing out a circuit. (using continuity function.)
Fault finding on a cooker. The reason is, because of it's size.
Where as my 2 Flukes, Hioki, Keysight and Brymen 867s are simply to big. The come into there own when you want more precise measurements, adjustment and logging.
I do own a Uni-T 61E and that's reserved for car where I don't mind it getting covered in oil and for checking out domestic wiring I use my Keysight U1242C (the torch comes in handy as well).
As a first Meter (I'm assuming here.) The Brymen BM257s hands down and get a high/er end one later if you need it.
Online coromonadalix
« Reply #4 on: February 10, 2019, 03:30:55 pm »
Brymen  257 series and up
But
Or at  least go or the 71D
thread:
https://www.eevblog.com/forum/testgear/uni-t-ut71d-review/
Offline shteii01
« Reply #5 on: February 10, 2019, 08:45:25 pm »
If you end up in electronics, than you don't need high voltage "stuff".
If you end up in industrial automation (PLC, 460 VAC 3 phase motors), than you WILL NEED high voltage "stuff".
If you end up in HVAC, you will need temperature and uA measurements.
If you end up in the field a lot, you will want none contact voltage detection too.
In conclusion.  Figure on having Fluke 116 and 117, or their equivalents from other brands.  The important fact is that you are a student and you don't know in what industry you will end up.  What does it mean?  Buy what you will use in your classes, buy it cheap and when you graduate, give it away or sell it because whatever you use in your classes is not going to be good enough for your job.
So.  Buy cheap, but with solid reputation.
Offline HoracioDos
  • Country: ar
  • Just an IT monkey with a DSO
« Reply #6 on: February 10, 2019, 08:52:16 pm »
You can also get a metrel md9016 (brymen  257s rebrand) in Europe a little bit cheaper than Brymen
« Last Edit: February 10, 2019, 08:58:36 pm by HoracioDos »
Offline Cnoob
« Reply #7 on: February 10, 2019, 09:24:58 pm »
The MD9016 is not a rebadged 257s the Min/Max and Crest buttons are blanked out and there is no Auto Check/Low Z selection.
I had a look at a couple of other brymans in with that form factor and the MD9016 is not one of those either.
It is a rebadged brymen, but which one?
Offline HoracioDos
  • Country: ar
« Reply #8 on: February 10, 2019, 09:49:28 pm »
Good to know.!!  I always thought they were the same product. There are some threads here that say so. My mistake.!!
Thanks for correcting me.
Offline Electro Detective
« Reply #9 on: February 10, 2019, 11:04:13 pm »
Good advice above, but suggest you consider two identical affordable meters.
You can do more, check one meter against the other to confirm readings,
and avoid show stoppers in the middle of a task if one breaks, dies, gets 'lost',
or everyones fav >  flat battery   :-[
Offline Fungus
« Reply #10 on: February 10, 2019, 11:25:17 pm »
Yes, you always need at least two meters.
But ... I woudn't get identical ones or you'll end up with two mediocre $60 meters. A decent $100 Brymen and one of those $20 ANENGs seems a better mix to me.
« Reply #11 on: February 11, 2019, 10:24:36 am »
Identical meters advantages = quicker learning curve, less thinking which meter has what inputs where, and what switching for what mode
= less fuse blowouts and or DUT drama
Besides, those   "Honey I think I shrunk the multimeter"   mini format just don't feel right somehow  :-//
I've tried the Aneng and clones and recently got a cheap unloved Fluke 101
It's ok... but the basic bare bones 114 leaves it in the dust
I'm not a pocket meter person it seems   :popcorn:
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #12 on: February 11, 2019, 11:22:11 am »
Since you mentioned reliability and durability, the mix below is a good one: start with the Brymen and save some for a cheaper meter. But keep in mind you don't need to rush into buying the second one - a single meter will do a lot for you already.
Although the Anengs are relatively cheap with many features, the competition is moving at a fast pace (and Aneng raised their prices since launch). The Mustool MT108T in my opinion is a much better meter for cheaper. A review by the resident expert HKJ is:
https://lygte-info.dk/review/DMMMustool%20MT108T%20UK.html
I also got a Mestek DM91A on a fire sale at Banggood for the same price of the Mustool above ($15) and it seems a somewhat decent meter, but I can't comment yet as mine is still on the boat.
Offline Fungus
« Reply #13 on: February 11, 2019, 01:37:49 pm »
I agree. I own an AN8008 and I hardly ever grab it when I want a quick measurement.
Which one do I grab? The ANENG 860B+ - decent size, good features, good solid feel. Only about $25
But I just checked and .... "[ur=https://www.aliexpress.com/store/product/ANENG-6000-counts-LCD-Digital-Multimeter-DMM-with-NCV-Detector-DC-AC-Voltage-Current-Meter-Resistance/919484_32799992769.html
l]no longer available[/url]"  :o
(on the official store at least, if you can find one anywhere else then grab them while you can)
Offline EEVblog
« Reply #14 on: February 11, 2019, 01:44:12 pm »
It's the BM252S
Offline EEVblog
« Reply #15 on: February 11, 2019, 01:49:17 pm »
The BM235 is 14€ cheaper and just as good (better in some aspects, worse in others) as the BM257
Offline Fungus
« Reply #16 on: February 11, 2019, 02:00:38 pm »
Can the 257 light up a white LED? The diode test voltage looks a little low to me.
Offline Cnoob
« Reply #17 on: February 11, 2019, 02:57:21 pm »
Thanks Dave for finding the right Brymen.
The 257 backlight is orange but you can see the 2 LED's shining on the right and the Diode test voltage is 1.5V.
