Author Topic: Circuit of low-end switching lab power supply (Tacklife MDC01)  (Read 3617 times)
Offline mcovingtonTopic starter
Does anybody out there have a circuit diagram of the Tacklife MDC01 (which is probably sold under other names)?  Or a similar low-end lab power supply (switching)?
This is the one I have: https://tacklifetools.com/products/dc-power-supply-variable-switching-dc-regulated-power-supply-with-4-digital-lcd-display-reverse-polarity-high-temperature-protection-110v-115cm-alligator-leads-included
It works fine -- I'm not needing to repair it -- but I'm always interested in knowing how my equipment works.
Avid Rabid Hobbyist
The following users thanked this post: mcovington
Re: Circuit of low-end switching lab power supply (Tacklife MDC01)
« Reply #2 on: June 28, 2020, 03:43:28 am »
Thank you!  I couldn't get a diagram from Tacklife -- they apparently don't build it, just label and sell it -- so I was hoping for diagrams of something similar (need not be identical).  Very much appreciated!
« Reply #3 on: June 28, 2020, 03:50:44 am »
That is not exactly the one, but it's definitely close enough to tell me how the designers think.  The one I actually have has 4-digit displays and has a fan controlled by a thermostat (off or on, almost always off).  So if a closer match turns up, I'll welcome it.  But I'm already off to a good start.  Thanks again.
Offline SunnyDay
« Reply #4 on: July 13, 2020, 03:44:39 am »
No schematic diagram, but some additional info.
It's a hybrid design, with a switching pre-regulator followed by an linear final stage, very similar to the Peaktech 6225A, which was reviewed by "Electro Bob" https://www.electrobob.com/peaktech-6225a-review/
One of his users posted a link to a reverse-engineered partial schematic of the control loop https://www.dropbox.com/s/wj405m435snhx5f/Peaktech%206225%20A.pdf?dl=0
And it looks identical to the HyElec model HY3005B, which has some teardown photos on this forum (text in Chinese), https://www.mydigit.cn/forum.php?mod=viewthread&tid=79335
« Reply #5 on: November 03, 2020, 04:11:00 am »
Sorry it took me so long to get back.  That (the Peaktech) is it, and the information is very helpful.  THANK YOU!
