The UT-210E is a good choice for home and hobbyist use. Just note that the hall effect sensor is very sensitive. For best results, null the meter prior to taking each measurement and don't move it or the wire during a measurement.
Variations in the magnetic field in the clamp and around the meter will affect your readings. Hence, the position and location of the wire within the clamp, the direction of current flow, the orientation of the meter, other nearby current-carrying wires, magnets, motors, etc., and even build up of magnetic flux in the clamp can cause values to be different.
Clamp meters are handy and good to have, but they do require additional attention, especially with low currents.
