I found a nice tutorial from Rohde & Schwartz regarding common misunderstandings about digital oscilloscopes. Believe it is very useful for beginners on this forum
Aside from the fact that there's a beginner's section in this forum where stuff like this should be placed, I hope you're aware that you're citing marketing arguments.
1) Your digital oscilloscope's bandwidth
Today's digital scopes use digital processing and employ very sharp, high-order frequency responses that trade minimum sampling rates for maximum bandwidth. The result is high overshoot and ringing when measuring typical digital signals.
That might be true for some entry-level scopes but most mid-range and high-end scopes do have a slow roll-off beyond the 3dB point, which obviously is news to R&S, as they seem to believe that their scope is exceptional in this area (which it isn't).
I'm not sure what a beginner is supposed to do with that information, or why R&S labels that as "scope lie".
2) Your digital oscilloscope's noise specification
Most high sample rate scopes will interleave two, four, eight (or maybe more) digitizers to obtain a sample rate that high. The digitizers need to be accurately interleaved to prevent interleaving spurs in the frequency domain, which manifests itself as noise in the time domain.
Again, this might be a problem for cheap/low-end scopes, but interleaving spurs aren't a problem for most mid-range and high-end scopes. Aside from the fact that in the price segment of the R&S RTO other manufacturers use much faster single-block ADC hybrids, which again seems to be news to R&S.
Again, I'm not sure where the "lie" is, or what relevance this has for a beginner.
3) Your digital oscilloscope's waveform update rate:
Can your oscilloscope really achieve its specified high waveform update rate (acquisition rate) using real signals?
Digital scope manufacturers specify high update rates in excess of 1 million waveforms per second which can be misleading. These update rates are usually stated for certain circumstances or settings, but typically do not include measurements or mask testing which may be turned on when acquiring waveforms.
Mask testing isn't a problem for any decent somewhat modern DSO except maybe some bottom-of-the-barrel scopes, and these are hardly the class of scopes that compete with an R&S RTO (a $15k+ scope). Math operations are different, but even the RTO slows down when using advanced math.
As before, I can't see where the "scope lie" should be, and as with the topics before it's generally not of much relevance for a beginner who's unlikely to use advanced maths anyways.
4) Your digital oscilloscope's analog trigger
Are you really triggering on the waveform you see on the screen?
Most scopes (analog and digital) utilize a separate trigger circuit and a different circuit to acquire the waveform. Since the trigger circuit and acquisition circuit have different bandwidths, different sensitivities and different characteristics, this can cause trigger jitter which appears as jitter on the signal, but is actually jitter coming from the trigger circuit.
Trigger jitter isn't a problem for most mid-range and high-end scopes, which also can trigger on any point in the signal. R&S seems to believe that other scopes work like an old Hameg CRO, which they don't.
Seriously, I'm not sure why you're posting such marketing drivel which R&S uses to promote their $15k+ high end scope, something that isn't of relevance for a beginner who'll very likely start with a slow and limited bottom-of-the-barrel scope like a Rigol DS1054z, or in some cases even with an old analog scope.
I'd also caution you to not blindly buy into any marketing BS, as you seem to do. Most of such stuff where one manufacturer compares his product with their competitors isn't worth the paper/the bytes its written on/with.
