As of X1, X2 values, they're likely display values related to end of capture.
X2 has 380s to the one end, and 620s to the other end, but it shows 1270s? X1 has also a value that I cant the the reference of.
Its actually the complete capture.
(Dont ask me how the rollmode worked in this case, since it is buggy.)
Edit:
It just struck me. There is this issue,where the trigger rate drops when using low sample rates (manual). One said, that there might be more memory filled, as you could see on the screen, and thus it cant trigger as you would expect. This could be the case here too, and there might be more in the memory than you can see. And this "end of capture" might be referenced too. No, that doesnt work. X2 then should have the smaller absolute value.
