Hi all,
I purchased a Voltcraft LCR-300, which is a Cyrustek ES51919-51920 based LCR meter (this is a big family including the not quite identical looking DER EE DE-5000, but my LCR has many identical clones as well - see post #4:)
https://www.eevblog.com/forum/testgear/voltcraft-lcr-300-micro-review/My first project with the LCR meter is to check the ESR of the electrolytic caps in my vintage transistor radio (ITT TOURING 103) and replace the bad ones.
This is also a good opportunity for me to check the IN CIRCUIT capability (ESR measurements) of the Voltcraft LCR-300 (if this meter can't do this, I will return it).
So could you please help me out with the following questions:
1. is it possible to measure the capacitor ESRs IN-CIRCUIT with these LCRs? The common answer to this question is "Yes it is possible because the 0.6Vrms test voltage will drop strongly when testing at 100kHz". The problem is that these LCRs can only test/measure bigger caps at LOWER frequencies (measuring range changes). That is, I can only measure my 1mF cap in my radio @ 1Khz (that would be only 120Hz if I had a 10mF cap). Will the test voltage drop enough at these lower frequencies?
2. is it safe to use the LCR meter in-circuit (no harm to components and speakers)? Also, is there any danger of blowing the tweeter when measuring the high-pass cap's ESR? (please see pic in the attachment)
3. The Voltcraft LCR-300 manual warns that components must be discharged when connected to the meter (I have several 1000uF/16V and 2.5uF/35V caps in the radio). Is it enough to simply unplug the radio's power chord (and press the power button) some hours before I take the measurements to be sure that all caps will discharge? (offtopic: this radio has a 12W AC to DC power supply (230v) - touching the inside of the radio would not pose any danger right?)
Sorry for the novice questions (I am quite a beginner in practical electronics). I posted this in "Test Equipment" because this is the place where all the relevant info on the LCR subject is located.
Thanks for your help,
b
