Author Topic: Datalogging thermometer recommendations.  (Read 2593 times)
Offline VgkidTopic starter
« on: September 23, 2015, 09:22:33 pm »
As the title suggest post your data logging thermometer reccomendations.
What i need is one that uses an external temperature sensor. It will be subjected to temps from -20 to 100C.
USB connectivity is preferred, and more than 1 chanel would be nice(2+ would be better).
BUT it must be cheap.
Not looking for real high accuracy.
Offline biot
Re: Datalogging thermometer recommendations.
« Reply #1 on: September 23, 2015, 11:47:14 pm »
Let me warn you about the UNI-T UT325: does everything you describe and inexpensive, BUT it only ever sends out data about one of its two channels -- big firmware screwup, since both are shown on  the display just  fine.
Offline radhaz
« Reply #2 on: September 24, 2015, 12:04:25 am »
There's a number of China usb data loggng thermometers on ebay cheap.
Offline TSL
« Reply #3 on: September 24, 2015, 06:24:51 am »
+1 radhaz
I've used one of these to track a misbehaving lab aircon
http://www.ebay.com/itm/BTHP02-2-Chs-Humidity-Temperature-Dew-Point-Data-Logger-USB-64K-32-000-readings-/281703381613
Stick it on the wall for a month and collect and plot later. :)
VK2XAX :: QF56if :: BMARC :: WIA :: AMSATVK
Offline AndyC_772
Offline Rick Law
« Reply #5 on: September 24, 2015, 07:25:16 pm »
If you want to make one, an Arduino with the LM35z from TI.
The TI LM35z is -55C to 150C with "typical accuracy" of 1/4C according to their datasheet.
This Arduino+LM35z solution works rather well for me, but I have not exposed the Arduino part to -20C.  I use a meter-long wire and stick only the LM35z part into the outside environment.
