It wouldn't hurt to let us know when there's new firmware available; you could post that in this thread@ Shannon
No problem, future updates will be shared here immediately
Also, I give you the list of all proposal I have made by PM to Shannon for firmware improvement:
(but I don't know if these ideas will be implanted
1) Shannon told me that the Hardware is 100kHz compatible, so hope to have this. hardware limitation?
2) Rdc: add a "quick" Delta/REL function with Joystick Up or Down
(as these button doesn't do anything on Rdc mode).
3) Rdc: in general calibration menu, add Open and Short calibration.
4) Diode mode:
- Short beep to tell good diode value (Voltage between 0.45V and 0.8V)
- Double short beep for schottky (Voltage between 0.1V and 0.45V)
- Continuous beep for dead diode (when shorted)
5) Change icon in Auto-Mode, as we don't really know when we are in AutoLCR mode or not.
(the Inverted "A" is showed breafly at the beginning, and then replaced by the mesured value)
I have attached moded photo of screen with my simple idea for that:
Inverted letter in AutoLCR mode, compared to normal letter in manual mode).
6) Shutdown on battery-charging at 100% if it is possible, to save Oled display.
7) Modify Diode test signal (From Shannon: "change the voltage first and then enable the output")
Thanks
Hello
Don't forget to post also the changelog
I use my ST42 very often, and I show it many times on my very little Youtube Channel too
Here (again
) some suggestions for GUI improvement, like my 2 years old post
from here I have put above :
https://www.eevblog.com/forum/testgear/design-a-new-precision-lcr-tweezers/msg5345456/#msg5345456Some are now implanted
Some new suggestions/ideas I have:
8 ) "Intelligent Auto-power Off" :
I use my ST42 very often, but sometimes it goes to sleep between 2 measurements
So I have to power up it again to use it.
And I don't want to set the timeout to "never".
So do you think you could add a timeout auto-reset when the ST42 measurement value change from a threshold value ?
9) New option in GUI:
If it is possible to add a menu to select the boot menu measurement of the ST42.
For now: it always restarts on the menu it was before the shutdown, which is good.
But, it would be great to add a menu where we can select manually between all the measurement boot menu, or keep last menu like this:
AutoLCR>R>L>C>|Z|>ESR>Diode>Led>Rdc>Last Menu
Thanks
