Author Topic: Discounter Multimeter  (Read 4475 times)
Offline mobochTopic starter
« on: December 03, 2019, 04:48:43 pm »
TÜV Certified... It's gotta be good
Re: Discounter Multimeter
« Reply #1 on: December 03, 2019, 06:43:40 pm »
It looks similar to the that Lidl's were selling a while ago and was reviewed on this site and there is some video on You Tube of it. It provides only very basic safety protection and is not a meter that I wish to use for high energy circuits or professionally but for a hobbyist it might OK, you would to make your own judgement on that issue.
Offline Gyro
« Reply #2 on: December 03, 2019, 09:57:06 pm »
I think Ferrex is Aldi.
Best Regards, Chris
Offline jnd
  • Country: cz
    • Personal stuff
« Reply #3 on: December 04, 2019, 10:50:57 am »
Too expensive and very basic meter, only slightly above the classic DT830B. This one looks like another version of DT9205A which you can buy on eBay for less than $7 shipped. Those full rotary switches with all manual ranges always show very old design only the most basic meters have. I would be surprised if it has better input protection than some Aneng for the same money.
Wannabe volt-nut, slowly hunting solid meters with low budget.
Offline Fungus
« Reply #4 on: December 04, 2019, 12:31:49 pm »
The trick is to look at the number in the picture:
Then you can go to this web site and type it in:
https://www.certipedia.com/
That leads you to a TUV certificate - and it's for a multimeter! (Tada!)
I youtube-reviewed a LIDL multimeter a while back, it was TUV certified, etc., just like that one.
https://www.eevblog.com/forum/testgear/heads-up-cheap-multimeter-lidl-uk-(080218)/msg1432827/#msg1432827
My meter is CAT III 300V, which seemed reasonable. It's basically rated for 240V domestic AC, nothing industrial or "high energy" (whatever that means).
I can't do full CAT certification here  :) but I did connect mine to 240V mains AC on all ranges except amps and it survived just fine. The fuses in mine are ceramic types with the right numbers/symbols printed on them so I assume the amps ranges would be uneventful if I did the same test.
I can't see the CAT rating on the meter in that photo but I expect it's similar.
Yep.
eg. https://www.aldi.co.uk/cordless-power-tools
ALDI aren't going to invent fake TUV/GS certifications. They just aren't.
« Last Edit: December 04, 2019, 12:36:48 pm by Fungus »
Offline Gyro
« Reply #5 on: December 04, 2019, 12:51:04 pm »
Nope, they don't cut corners like that, and TUV aren't some backstreet lab (they're expensive).
There are times when a cheap manual ranging meter can be very useful - when the value is rapidly changing (driving the autoranging into a siezure), or when a voltage is outside your expected range, where a quick OL reading is a useful warning. They are much quicker to set to a manual range that turning off autoranging and selecting the appropriate range in such circumstances.
« Last Edit: December 04, 2019, 12:52:59 pm by Gyro »
Best Regards, Chris
Offline DarrenWalker
« Reply #6 on: December 17, 2019, 12:58:38 am »
https://youtu.be/aYArKnCHLeU
This video is 2.5 years old but the meter internals probably haven't changed.
A decent and fairly accurate DMM that although not very exciting at least doesn't break the bank.
