Author Topic: Discussion : SMD Test Fixture (Two terminals, Kelvin connections type)  (Read 9215 times)
Offline BravoVTopic starter
  • +++ ATH1
Always drooling on those pro 2 terminals Kelvin connections SMD test fixture, like the one used for benchtop LCR meter or resistance measurement, they are always pricey, even used.  :palm:
Btw, I mean here is not SMD Kelvin tweezers or clips, but the fixture such like the attached photo below as example. (Randomly grabbed from Google) and I'm aware there are so many types of them.
Whats your favorite ones or mostly used ? Or any DIY or even ghetto made one ?
Please share your thought/experience or discuss about it here.
Also, really appreciate if any you that have access/own this precious tool, please, if its not too troublesome,  post few close up shots where its in action, like before/after the DUT is installed.
Really want to build one for my bench top LCR meter, hopefully can gather thoughts, ideas or designs from you all.
TIA
« Last Edit: March 16, 2016, 03:26:59 pm by BravoV »
Offline Carrington
Cheaper one, it's not 4-wires, but I guess that it can be modified:
http://www.tequipment.net/ExtechLCR205.asp
A DIY Idea using two male micro USB connectors (see below).
Maybe not the best solutions, but I hope that this helps in some way.  :)
« Last Edit: March 16, 2016, 08:23:35 am by Carrington »
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
  • +++ ATH1
Carrington, thanks for the reply.
Yes, I'm aware of those tweezers or clips, but those are merely for quick measurement for handheld application.
What I'm looking for is a firm test fixture for holding the DUT long enough and have reliable contacts during measurement, this is needed when doing profiling or like scanning the DUT which sometimes will take a while.
« Last Edit: March 16, 2016, 04:12:47 pm by BravoV »
Offline Carrington
You are welcome.
Look this beast:
Link: https://www.skgautomation.com/model-570-precision-test-fixture.html
About its price, probably a lot money.
But look here: http://www.wilcocontrol.com
They probably have something more economical, I have seen a kit for less than $100.
They can easily make something like this:
Space Weather.
Offline Carrington
Perhaps someone dares to do something using parts from a old DVD/CD, PCBs, and some plastic parts.
But, I don't!
Space Weather.
Offline The Electrician
I've got one of these: http://www.ebay.com/itm/NEW-LCR-RCL-METER-TEST-FIXTURE-FOR-SMD-COMPONENT-/351672522740?hash=item51e150d7f4:g:lGYAAOSw7I5TsiWf
I'll post a picture of the insides.  It isn't suitable for very high frequency measurements, as will be apparent!
Offline Carrington
Probably not, because of its internal construction. Internally it's a bit dodgy, I've seen it, but I don't have any image.
Space Weather.
  • +++ ATH1
Carrington, yeah, I'm aware of those commercial fixtures, especially the metal beast, simply way beyond my league I'm afraid.
About salvaging the old optical drive parts, or printers for making the fixture, hey, thats actually a good idea.  :-+
Also curious about the materials used, like the white plastic, I guess its PTFE isn't it ? And of course the internal constructions too if its possible. Many thanks in advance.  :clap:
About frequency, my LCR capable of sweeping up to 1 MHz, is it too high for that ?
Here are pictures of the fixture I got from China.  I did just a bit of testing, and it looks like the maximum upper useful frequency is about 1 MHz, maybe.
« Last Edit: March 18, 2016, 08:25:13 am by The Electrician »
Offline iampoor
Is anyone aware of an 0805 socket? I know Peak made a sot-23 adapter for there analyzers. Looked pretty nice an not too pricey!
Offline Carrington
Re: Discussion : SMD Test Fixture (Two terminals, Kelvin connections type)
« Reply #10 on: March 18, 2016, 09:15:39 am »
    Frequency: DC to 40MHz
    DC Bias:+/- 40V peak max (AC+DC)
    Operating Temperature: 0 to 55 degrees C
    Terminal Connection: BNC, 4 terminal-pair
    Dimensions(approx.): 128(W) x 60(H) x 71(D)mm
    SMD Test Fixture Selection Table
Source: http://www.keysight.com/en/pd-1000000045%3Aepsg%3Apro-pn-16034E/test-fixture-smd-components
Space Weather.
Offline Carrington
« Reply #11 on: March 18, 2016, 09:17:39 am »
Good pictures, not bad!  :-+
The one I saw was not the same.
Space Weather.
  • +++ ATH1
« Reply #12 on: March 19, 2016, 10:08:21 am »
The Electrician, thank you so much !  :-+
Interesting construction, noted, especially the middle plate of the internal construction between the two terminals, is the plate's purpose for reducing the parasitic capacitance of the fixture it self ?
« Reply #13 on: March 19, 2016, 10:47:08 am »
I would assume so.  I haven't seen the inside of a real Agilent version, but those long unshielded wires from the BNC connectors to the contacts are limiting high frequency performance.
  • +++ ATH1
« Reply #14 on: March 19, 2016, 11:44:14 am »
About the limiting factors, is that because of not using PTFE wires ? Or anything else ?
Btw, about the 4 coax outer shields, they're all connected internally like that, is that a good enough ? Or there are even better method ?
The reason I ask this is because I saw the cablings inside the genuine Fluke PM6306 RCL external measurement box, it has separated ground wire, the black wire that is screwed to the box's chasis.
Image of Fluke/Philips 9542A adapter box.
Courtesy of forum member : HighVoltage
Offline hexamer
« Reply #15 on: November 23, 2019, 06:57:16 pm »
Sorry for resurrecting this zombie thread, but I wanted to report back on something.
I found this thread because I was thinking about DIY'ing something for my BK-880.  The Extech LCR205 mentioned here looked exactly like what I wanted to do, but it was reported that it's not Kelvin connected.  That makes sense since the EX-200 LCR meter it was built for isn't Kelvin either AFAICT.  I found it very reasonably priced on Amazon so I bought it and some 1.2mm 2 sided PCBs in the hopes that I could modify it to be Kelvin connected.  When it arrived I was surprised to see that it did have both sides of the PCB plated, so I put it in my BK-880 and it works great.  Took it apart just to see how it's constructed - apologies for all the dog hair in the pics!
EDIT: Well ... it was reasonably priced.  For some reason the one I bought was $31.58 USD with Prime.  Now it's $79 from the same seller :(  Hope this one holds up!
« Last Edit: November 25, 2019, 11:49:22 pm by hexamer »
