Author Topic: DIY Test Gear  (Read 6510 times)
Offline simba15Topic starter
DIY Test Gear
« on: February 16, 2022, 08:20:09 pm »
So I seem to always be looking for DIY test equipment
It might be great to have a thread of projects that members have build or experiences or jsut think are great.
There are tons of them that I can find, but hard to say if they are good or the best. (I prefer simple ones with single side pcb and DIP chips)
A few ideas would be
PC Oscilloscope:
http://electronics-diy.com/electronic_schematic.php?id=703
https://www.martinloren.com/hs40x-diy-oscilloscopes/
https://www.electronicsforu.com/electronics-projects/pc-based-oscilloscope-using-arduino
https://github.com/fhdm-dev/scoppy  (my fav)
Function generator:
http://electronics-diy.com/1hz-to-1mhz-xr2206-function-generator.php
http://www.vwlowen.co.uk/arduino/xr2206/XR2206-function-generator.htm
https://circuitdigest.com/microcontroller-projects/arduino-waveform-generator
Power Supply:
http://www.electronicecircuits.com/electronic-circuits/variable-power-supply-0-24v
https://solderingmind.com/diy-variable-power-supply-with-adjustable-voltage-and-urrent/
Programmable Load:
https://juangg-projects.blogspot.com/2019/02/arduino-based-electronic-load.html
https://circuitdigest.com/microcontroller-projects/adustable-electronic-dc-load-using-arduino
I hope others feel they can contribute and put forth any other projects and results.
I would love to document a series of DIY test tools that any beginner can build for a reasonable price.
« Last Edit: February 21, 2022, 02:34:36 pm by simba15 »
The following users thanked this post: sab
Offline Bud
Re: DIY Test Gear
« Reply #1 on: February 16, 2022, 08:39:13 pm »
We had such thread , i do not have a link though. There was cool stuff people posted in it.
Offline Andrew_Debbie
Re: DIY Test Gear
« Reply #2 on: February 16, 2022, 10:10:04 pm »
I've got a few personal projects.  All are simple.  None of them are fully documented.   If there is enough interest I can put them on Github.
They are all based on a 100x100 or 100x50mm PCB.     The PCBs mount on a 100x100 or 100x50 base plate, which saves on a case.   The base plates are KiCad templates.
5V and 3.3V buck-boost --> linear supply which can be battery powered, or from an off-board supply.   I built this as an easy way to get isolated power for another 50x100 module.   Swap two parts for a different pair of voltages.
Inexpensive modulated 455kHz signal generator.   Useful for repairing old radios, since most of  them use 455kHz IF.   *This is mostly copied from an old magazine construction article which shows how to build it on strip board. I first built this many years ago and decided to make it again as a 50x100mm module.
Unregulated  linear DC power supply.  Uses Amveco/Talema 25VA transformer. Has input filter.   Of course this needs to go in a case not on a plate.
I've got several more modules in various stages of development.
« Last Edit: February 17, 2022, 09:46:24 am by Andrew_Debbie »
Offline bob91343
Re: DIY Test Gear
« Reply #3 on: February 17, 2022, 12:00:52 am »
I like the TDR pulser, and the low resistance Ohmmeter.  And the noise bridge.
Offline devinatkin
  • PhD Student at the University of Calgary I2Sense
Re: DIY Test Gear
« Reply #4 on: February 17, 2022, 07:15:42 pm »
I need to make a nano-voltmeter for research purposes, it's not the center point of the research but is going to be essential to getting good results. (Can't use off the shelf stuff cause it needs to be cheap and ruggedized to be hauled out to the middle of nowhere and run off a battery pack, target BOM $100-300). If I'm actually successful in getting good results I certainly plan to document and release it. If someone is aware of an existing project which I can either clone or purchase in that price range I'd be eternally grateful.
I keep making excuses to kick the design down the road, but I've got to get a proper start on it by the week after next at the latest.
Re: DIY Test Gear
« Reply #5 on: February 17, 2022, 07:44:49 pm »
Interesting i wonder how to find it ( keywords are kinda vauge here)
Thanks everyone for there contributions!
Here are a few more (more complex, not single side pcb and dip chips here)
EEZ Power supply:
https://github.com/eez-open/psu-hw
32 bit Sigma-Delta ACD (8.5 digit muitimeter (Marco reps)
https://ohwr.org/project/opt-adc-10k-32b-1cha/wikis/home
Re: DIY Test Gear
« Reply #6 on: February 18, 2022, 11:12:48 am »
« Last Edit: February 18, 2022, 04:17:57 pm by Andrew_Debbie »
Offline not1xor1
Re: DIY Test Gear
« Reply #7 on: February 19, 2022, 08:37:04 am »
Power Supply:
just had a quick look at that.
it is ugly (it might have been good 70 years ago when the first BJTs became available) and the schematic does make no sense as the collectors of T1 and T2 should be connected to the anode of D2 whose only purpose is to reduce the effect of the ripple voltage for the zener reference. Current limit is rather coarse and inefficient. There are tons of better schematics.
Offline Bud
Re: DIY Test Gear
« Reply #8 on: February 19, 2022, 11:26:42 pm »
Found it
https://www.eevblog.com/forum/testgear/show-the-homemade-equipment-you-are-using-now/
Re: DIY Test Gear
« Reply #9 on: February 21, 2022, 02:34:13 pm »
Power Supply:
Thanks for checking it! I will remove it as its best not to highlight the poor designed ideas.
Can you provide any better designs?
Thanks.
Re: DIY Test Gear
« Reply #10 on: February 21, 2022, 02:35:14 pm »
Found it
Thanks! Some good ones in there!
Do you have any more info about the USB/GBIP adapter you made?
Could use a few.
The following users thanked this post: bob91343
Offline kripton2035
Re: DIY Test Gear
« Reply #11 on: February 21, 2022, 03:37:21 pm »
low ohm meter and short circuit finder
http://kripton2035.free.fr/Projects/shorty-display.html
Re: DIY Test Gear
« Reply #12 on: March 13, 2022, 07:51:20 am »
Modulated 455kHz signal generator complete.
This is a low cost signal generator for troubleshooting.
I'm happy to share details if anyone wants to copy it.   Eventually I will put the files on github.    Original idea came from an old magazine article.
« Last Edit: March 13, 2022, 07:57:57 am by Andrew_Debbie »
Offline bob91343
Re: DIY Test Gear
« Reply #13 on: March 13, 2022, 05:56:21 pm »
You could bring down the frequency a bit by increasing C4 and/or C5.
Offline free_electron
    • SiliconValleyGarage
Re: DIY Test Gear
« Reply #14 on: March 13, 2022, 06:07:16 pm »
Elektor had a whole pile of test euipment they published in the 80's and 0. i built many of them. function generator , pulse generator , capacitor meter , power supply ,  quadrant supply, multimeter , lrc meter , frequency counter.
use internet archive to find the information
Offline pcprogrammer
Re: DIY Test Gear
« Reply #15 on: March 13, 2022, 08:10:35 pm »
I'm playing around with a lichee nano, an Anlogic FPGA module, an AN9767 DAC module and an AD9226 ADC module. Not much working yet, but it can become a nice multiple in one instrument. Not super high frequency, but the DAC is 14 bits and can run on 125MHz. The ADC is 12 bits and can do 65MSa/s.
First up is an AWG or DDS. Making FPGA programming in verilog is new for me so a lot of trial and error, but I managed to get it running on 125MHz outputting a sawtooth on 7629Hz. Also able to get a variable frequency but something is wrong in the FPGA programming, because the second channel does not work properly.
It is for fun and learning FPGA. The lichee nano is reasonable capable for doing the human interface and displaying.
It will end up in my lichee nano repository: https://github.com/pecostm32/Lichee_Nano There already is some stuff in there about the hardware and some test software.
I don't have a 3D printer so used a bit of left over wood to stick it on.
Re: DIY Test Gear
« Reply #16 on: March 13, 2022, 08:46:47 pm »
I might.  It is already  close enough for troubleshooting old AM radios, which is what I use it for.
455kHz ceramic resonators are cheap but not high precision.   The part I'm using is rated +/- 2kHz at 25C.  It can drift a few tenths of a percent with temperature.
« Last Edit: March 14, 2022, 03:33:10 pm by Andrew_Debbie »
