Author Topic: DMMCheck Plus Multimeter Reference(and other References) - Experiences..  (Read 72454 times)
0 Members and 18 Guests are viewing this topic.
Offline bdunham7
Re: DMMCheck Plus Multimeter Calibration Reference - Experiences ?
« Reply #100 on: July 11, 2023, 09:01:57 pm »
At the moment my SDS2504HD measure the same signal - without "deforming"...
Must investigate this.
The SDS1104X-E was not set to AC coupling, was it?
I think this is a known issue with the scope at low frequencies.
Here's 100Hz 10Vp-p from SDG2042X direct to SDS 1104X-E with settings as shown.
« Last Edit: July 11, 2023, 09:04:48 pm by bdunham7 »
The following users thanked this post: alm
Offline Domitronic
« Reply #101 on: July 11, 2023, 09:12:53 pm »
Yes, at least my SDS1104X-E has the same issue:
https://www.eevblog.com/forum/testgear/siglent-sds1204x-e-released-for-domestic-markets-in-china/msg4433131/#msg4433131
Others reported the same in this thread.
Online Martin72Topic starter
« Reply #102 on: July 11, 2023, 09:13:07 pm »
Yepp, it must be an issue - connect the signal directly without a probe to the scope, no changes.
Hmm..Not so nice for SDS1104X-E owner.
Offline Veteran68
« Reply #103 on: July 11, 2023, 09:19:00 pm »
I'm shocked, SHOCKED!, I tell you!  :D
I knew when I got it that there was no way they were typing up, printing, and cutting out each of these for each unit. The handwritten ones are much more believable.
The date on it should be a giveaway. When did you buy yours?
Had to search email history to figure out where and when I bought it.
EBay, Feb 2020. So yeah it came with 5yo cal sheet from some other device (if not entirely made up numbers to begin with).
I had bought a few different varieties of these cheap ones, like the other ones pictured in this thread, but this one was an odd duck with its battery requirement so after I was done playing with it, it went into a drawer and was never used again.
Since then I bought a LB02A process calibrator which is handier and more fun to use, and is really all the reference I need for my hobby purposes.
« Reply #104 on: July 11, 2023, 09:32:11 pm »
Now the SDS2504X-HD...
You musn´t buy this to get the nice histograms, you could have them with a unlikely more cheaper SDS2000X-Plus.
But the accourate DVM, you get it only with the 12bit model.
« Last Edit: July 11, 2023, 09:34:11 pm by Martin72 »
Online KungFuJosh
  • TEAS is real.
« Reply #105 on: July 11, 2023, 10:08:06 pm »
I love the details on the HD's measurements.
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
« Reply #106 on: July 12, 2023, 08:21:33 pm »
Meanwhile I remember of my third LCR meter I got, a mastech MS8911 smart smd tester with testfrequencies up to 10khz..Must check it too.
Did it, it´s not too bad... ;)
Testfrequency 10khz..(reference)
1050 µH (1032µH)
104.8µH (104.3µH)
10.5µH (10.52µH)
1µH (1.061µH)
1.017nF (1.019nF)
10.14nF (10.16nF)
102.3nF (102.5nF)
1.013µF (1.001 µF)
DCR
100.0 Ohm (100.058)
0.999 kOhm (0.9994)
9.999 kOhm (9.9995)
100.0 kOhm (100.017)
« Last Edit: July 12, 2023, 08:28:36 pm by Martin72 »
Offline tatel
« Reply #107 on: July 13, 2023, 07:21:15 am »
Now that I got this thing and almost half a dozen multimeters, I reckon it's time for me to work out some spradsheets. So here it's my first try at it. All I can say it seems to work. But, since I really don't know what I'm doing, please feel free to criticize it sharply and maybe even use it
« Reply #108 on: July 13, 2023, 11:46:03 am »
I have taken the liberty of making it more visible, your notes on the sheet as a quote:
Notes: The sticker in DMMCheck+’s back says AC Amps uncertainty is 0.2% but in the manual I see 0.5%. Am I high?
The sticker also says L, C are calibrated to 0.05% but nothing is said about it in the manual.
No TC specified for many DMMCheck+ measurements. Uncertainty min/max is calculated first. Then, available TC is added/substracted to uncertainty.
869s TC isn’t calculated if T is in the 18-28 Cº ranges. Otherwise it’s added/substracted to uncertainty.
869s’ DC V in dual mode reads 5.0011V. Single mode reads 5.0000 and 5.00006 V. So dual mode = less precision?
No Hz reading when measuring AcmA (0.000), however Hz reading is OK when reading ACV
Here my BM869s results:
https://www.eevblog.com/forum/testgear/dmmcheck-plus-multimeter-calibration-reference-experiences/msg4950205/#msg4950205
Interesting thing with the dual display, must check this too.
L/C values: Indeed it´s only measured with a device which got 0.05% basic precision.
« Last Edit: July 13, 2023, 11:50:03 am by Martin72 »
« Reply #109 on: July 13, 2023, 04:21:43 pm »
Indeed, according to the manual single mode display is only avaible in DCV mode, also the 500000 counts.
Only when DCV, nothing else.
Offline tatel
« Reply #110 on: July 14, 2023, 12:54:01 am »
What looks strange to me is that 11 counts difference between DCV in dual mode vs single mode in 50000 counts mode. I mean, shouldn't be the involved guts be almost exactly the same? turning on some more led segments is enough to get a 0.02% difference?
Not that I care so much about it, but I was expecting it to read exactly the same in both display modes.
Offline J-R
« Reply #111 on: July 14, 2023, 02:42:36 am »
Frequency measurements are possible in ACmA mode on the BM869s, but it may not display at very low currents.
Also, you can only calibrate DCV and ACV ranges, not any of the combined modes.  The readings in combined mode can be up to 80 counts off.
I didn't have time to dig further to see what is causing the error.  I think I will calibrate the ACV mode and see if that impacts it.
Offline bdunham7
« Reply #112 on: July 14, 2023, 02:47:09 am »
On most meters with dual-display modes they still only have one ADC so they can't measure simultaneously.  When they switch back and forth between modes, the meter may not be able to settle quite as fully as it would in the single display mode.  This slight (or in some cases not-so-slight) degradation happens with almost all meters with these dual modes.
Offline tatel
« Reply #113 on: July 14, 2023, 07:31:29 am »
Thank you. Seller has about the same opinion. I measured ACV on the "I" outputs of DMMCheck, got about 0.5V. Then I measured ACmA on the "V" terminals, so 5V. I got a good 100 Hz and 10 kHz readings at about 28mA.
So it turns out this DMM works fine and DMMCheck+ output is somehow too low on the "I" terminals for it to read Hz on the mA mode.
« Reply #114 on: July 14, 2023, 09:27:01 pm »
Got an answer from welectron about additional calibration of the DMMCheck plus.
Will cost about 85€, pro would be a "real" calibration according to ISO standards, including a report - I already knew it from my brymen.
Con: 85€... ;)
Will sleep about it, then decide.
The following users thanked this post: Kean
Online KungFuJosh
  • TEAS is real.
« Reply #115 on: July 14, 2023, 10:45:24 pm »
Con: 85€... ;)
For 25€ I can scribble out the AD584 and doodle in DMMCheckPlus on this paper, and it will be just as useful. 😉
« Reply #116 on: July 14, 2023, 10:53:38 pm »
Such "scraps" of paper do not interest me at all, because completely worthless. ;)
There is even the option to have the checker calibrated according to DakkS...
But then it becomes three-digit in terms of price.
That does not have to be, for the hobby.
Online KungFuJosh
  • TEAS is real.
« Reply #117 on: July 14, 2023, 11:55:00 pm »
That's my point. 😉
Since this is just for hobby use, and it already has some level of calibration, do you really benefit from spending more money on calibration? I'd save that cash and spend more money on their new improved model. 😉😉
« Reply #118 on: July 15, 2023, 12:12:26 am »
When it comes with the same sheet of paper it is as useful as the "old" one.. ;)
And as long as they would use the same reference IC nothing great will change, maybe the stability but this you can check with a period calibration, regardless if new or old version.
When I want to know if it´s "true", it should be worth the money.
My skepticism started when I realized that the components on the L/C board are not high accuracy types, but only those that were measured with their LCR meters.
Then most of the values are rounded.
It may be that I am "damaged" by my profession in this respect, but if it is advertised that it should be a device for the calibration of other devices, then it should also be documented extensively.
Online KungFuJosh
  • TEAS is real.
« Reply #119 on: July 15, 2023, 02:03:44 am »
I would return it if you don't feel it's reliable or accurate enough. For what you're investing in it plus calibration, you could build your own test board with whatever components & accuracy level you want, and then send the board you made to be calibrated. IMHO that would be a better reference.
For me, that would be more entertaining, and less expensive. Hmmm. Maybe I'll make a test PCB for all the SMD stuff I got for calibration. 🤔
Edit: aaaand I already drew a schematic for it. Super simple for a passive test board.
« Last Edit: July 15, 2023, 02:49:04 am by KungFuJosh »
Offline J-R
« Reply #120 on: July 15, 2023, 08:08:17 am »
Ran some LC tests:
The following users thanked this post: Kean, alm, Martin72
« Reply #121 on: July 15, 2023, 11:18:34 am »
Ah, the good old DE5000 - Most underrated lcr-meter ever.. ;)
Offline mawyatt
« Reply #122 on: July 15, 2023, 12:42:23 pm »
Something like these?
Which are obviously directed towards bench type DMMs with the 4 banana plugs directly on the PCBs.
Edit: Second image came in upside down, so it's measuring Mhos not Ohms  ;D
Best,
« Last Edit: July 15, 2023, 12:59:46 pm by mawyatt »
~Wyatt Labs by Mike~
Offline mawyatt
« Reply #123 on: July 15, 2023, 01:19:50 pm »
Here you can see the test fixture with another DMM measuring its temperature, altho we haven't found this feature very useful but included such just in case.
Best
« Reply #124 on: July 15, 2023, 01:20:34 pm »
Remember my post ?
https://www.eevblog.com/forum/testgear/th2830-vs-th2832/msg4957831/#msg4957831
