Author Topic: Do linear power supply switch range?  (Read 1692 times)
Offline BeBuLamarTopic starter
« on: May 11, 2021, 01:41:29 pm »
I just bought a Matrix MPS-3605LP last month. It's a 36V 5A power supply. I found it's OK for the price of $129 but I notice something. I hear relay clicking when I adjust the voltage between 12-13V and also between 25-26V. So do you think that it switches the input voltage so to reduce the voltage difference between input and output which can cause it to get very hot?
Online HKJ
    • Tests
Re: Do linear power supply switch range?
« Reply #1 on: May 11, 2021, 02:08:32 pm »
Yes, many linear power supplies has relays to change input voltage.
Offline Doctorandus_P
« Reply #2 on: May 11, 2021, 02:10:48 pm »
Yes, this is very common for lineair power supplies.
Ever since the '70-ies or earlier they use transformers with multiple taps to reduce dissipation in the power supply.
Dave has made a teardown of the Korad 3005 power supply long ago, and you will find something similar in almost any variable output lab power supply.
A more modern approach would be to use an SMPS with variable output voltage as a pre regulator, and then a linear regulator (which drops just a few volts) to clean up the switching noise, but these are not so common. My guess is that if you want to make a low-noise power supply, then the cost and weight of a chunk of iron in a transformer is still attractive because it just does not generate any HF noise by itself. The weight is also not an issue for a power supply that just sits on a shelf.
There are lots of SMPS modules, which are cheap and practical for delivering lost of raw power, but these have quite some switching noise.
Offline radiolistener
  • Country: Earth
« Reply #3 on: May 11, 2021, 02:22:48 pm »
yes, high voltage drop on linear regulator leads to a high heating and low efficiency. Reduce voltage with relay switch between different transformer output allows to reduce voltage drop and heating. Relay switch doing this job.
