Author Topic: Do logic analyser cables with test clips at both ends exist?  (Read 634 times)
Offline 5U4GBTopic starter
« on: April 15, 2025, 12:48:33 pm »
I sometimes need to temporarily hook up 8-, 10-, or more-pin setups, which end up covered in wire spaghetti when using standard single-wire-with-grabber-clip connections.  My Google fu is failing me on this, there's tons of standard test-clip-to-DuPont-connector ribbon cables for logic analysers around but I can't find any that have test clips at both ends.  Worst case I could kludge it by plugging in DuPont-male to DuPont-female ends of cables back-to-back, but it'd be nicer to have a single ready-made cable that does this.
The signals going over it are low-speed serial, dry-contact, and similar, so any generic product is fine, I don't need anything exotic.
Does anyone know of anything, or an appropriate Google search term, to find this if it exists?
Offline RAPo
Re: Do logic analyser cables with test clips at both ends exist?
« Reply #1 on: April 15, 2025, 01:01:24 pm »
I use these clips on both ends of a Dupont cable.
The following users thanked this post: 5U4GB
