EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
DS1052E controls question
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: DS1052E controls question (Read 3419 times)
i_like_sparks
Contributor
on:
September 19, 2013, 02:04:44 am »
Hello,
excuse a probably stupid question from a beginner.
Let's say I'd like to use my new shiny DS1052E to measure the ripple/noise on a +12V signal. I know it's at 12V and want to zoom in to the 20mV level centered around +12V. If I first set the vertical scale to 20mV it takes ages spinning the vertical position knob to get up to 12V. Hmm... Ok, next time I set the vertical position to 12V first at the, say, 10V level, and THEN try to zoom in to 20mV. BUT this changes the vertical position as well, and it is now at 24mV, so I'm wheeling the vertical position knob again to get up to 12V...
This is incredibly annoying. I must be missing something obvious. Can anyone enlighten me?
Logged
AG6QR
Frequent Contributor
Country:
Re: DS1052E controls question
Reply #1 on:
September 19, 2013, 02:10:13 am »
If you want to look at the ripple, switch to AC coupling. Now the signal is centered around the origin. This also improves the resolution of the samples.
Logged
Psi
Super Contributor
Country:
Reply #2 on:
September 19, 2013, 02:11:29 am »
Use AC coupling mode to measure noise.
Since you're not concerned about the actual voltage, you just want to see how much its moving up and down by. Which is AC
AC mode doesn't move when you adjust the vertical scale.
Logged
i_like_sparks
Contributor
Reply #3 on:
September 19, 2013, 02:32:32 am »
Ah, that's very useful.
Still, I think this is not a good design. If the display is centered around 12V and I'm switching vertical scale it should be obvious that I'd still like to have it centered around 12V and not, say, 6 or 3 instead.
Logged
sync
Country:
Reply #4 on:
September 19, 2013, 02:38:05 am »
This is how analog scopes works. But you can change it:
Utility -> Preferences -> Expand Refer. -> Center
Logged
i_like_sparks
Contributor
Reply #5 on:
September 19, 2013, 02:44:30 am »
Thank you so much, that's exactly what I was looking for. Hadn't found that menu yet.
Logged
Psi
Super Contributor
Country:
Reply #6 on:
September 19, 2013, 05:23:22 am »
lol, i didnt know about that setting.
Thanks
Logged
rdl
Super Contributor
Country:
Reply #7 on:
September 19, 2013, 04:10:56 pm »
omg! That has been bugging me ever since I got this scope. Thanks for the tip. Maybe I should read the manual some time.
Logged
Mechatrommer
Super Contributor
Country:
reassessing directives...
Reply #8 on:
September 20, 2013, 04:22:44 am »
yeah its usefull when the dc level is not changed.
Quote from: i_like_sparks on September 19, 2013, 02:32:32 am
what do you expect from a $300 scope?
Logged
The Ultimatum of False Logic
and
The Great Delusion
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
