Author Topic: DSO 5072P input stage problem  (Read 1383 times)
Offline YannickFTopic starter
« on: July 08, 2017, 09:19:46 am »
Hello
I think I burnt the input stage on my oscilloscope this morning.
I was looking for the pulse output (in order to build a tachometer) on a motorcycle alternator, and maybe too high voltage was applied.
Actually, both CH1 and CH2 are OK (tested with 5V 1Khz output) but they don't work at all if I choose 5V/div sensitivity. (Signal stay on 0V)
Which component(s) may have been killed ?
Regards
Offline homeboy
Re: DSO 5072P input stage problem
« Reply #1 on: July 09, 2017, 09:39:24 pm »
Directly go to this website: "www.eediscuss.com" to bring up your question. May be technical support can give you a hint.
