I've just started looking at a Solartron 7081 that I bought for repair ... it has an NVM FAIL error, which is not suprising given the ER3400 is completely missing!
But while I wait for a new(ish) one to arrive I've been looking at other issues ... and I'm a bit confused about the battery situation.
The battery on the lower board is a 3.6V lithium inorganic battery which is completely dead ... I'm assuming I can just replace this with another 3.6V lithium battery, something like this:
https://uk.farnell.com/eve/er14250p/battery-lithium-1-2aa-3-6v-axial/dp/1365936The battery on the IO Board is the one that's confusing me ... in a number of the forum posts about the 7081 this is talked about as a Ni-Cd and is indeed shown on the schematic as a 3.6V NiCAD with what looks like a charging circuit.
At least one person has replaced this with a supercap, which I understand ... however, both in my device and in a number of post in the forum this has been replaced by a lithium battery ... in my case an RS 593-473, these are not rechargeable!
Surely this is a problem?
Wouldn't I be better off with one of these?
https://cpc.farnell.com/varta/55615603940/battery-ni-mh-mempac-pcb-3-6v/dp/BT00152?ost=bt00152
