Author Topic: Solartron 7081 Battery Question  (Read 1374 times)
Offline esseleTopic starter
« on: October 30, 2021, 10:30:16 am »
I've just started looking at a Solartron 7081 that I bought for repair ... it has an NVM FAIL error, which is not suprising given the ER3400 is completely missing!
But while I wait for a new(ish) one to arrive I've been looking at other issues ... and I'm a bit confused about the battery situation.
The battery on the lower board is a 3.6V lithium inorganic battery which is completely dead ... I'm assuming I can just replace this with another 3.6V lithium battery, something like this: https://uk.farnell.com/eve/er14250p/battery-lithium-1-2aa-3-6v-axial/dp/1365936
The battery on the IO Board is the one that's confusing me ... in a number of the forum posts about the 7081 this is talked about as a Ni-Cd and is indeed shown on the schematic as a 3.6V NiCAD with what looks like a charging circuit.
At least one person has replaced this with a supercap, which I understand ... however, both in my device and in a number of post in the forum this has been replaced by a lithium battery ... in my case an RS 593-473, these are not rechargeable!
Surely this is a problem?
Wouldn't I be better off with one of these?  https://cpc.farnell.com/varta/55615603940/battery-ni-mh-mempac-pcb-3-6v/dp/BT00152?ost=bt00152
« Last Edit: October 30, 2021, 11:25:55 am by essele »
Offline justanothername
  • Country: at
Re: Solartron 7081 Battery Question
« Reply #1 on: October 30, 2021, 12:10:16 pm »
It has a charging circuit, so the normal way would be to change to a supercap or a NiMh battery.
Since it does trickle charging it is not that critical to use NiMh instead of NiCd. If you want to be safe, change R403 to 1k or higher.
However you can use a primary cell (Li-SOCl2 - the have a large capacity). Then you may want disable the charging circuit. The easiest way would be to desolder R403.
Offline HPIB
  • Country: cz
« Reply #2 on: December 02, 2025, 08:49:51 am »
Do any of 2 batteries in 7071/7081 backup calibration data? If I remove them for cleaning boards and put new batteries in, will calibration still remain intact? Ni-cd/Ni-mh should be ok (RAM), but what about Lithium one?
Online perdrix
« Reply #3 on: December 03, 2025, 04:39:39 pm »
If memory serves, you can use a Varta V150H 3.6V NiMH 150mAh to replace the NiCd
All calibration data is held in the ER3400 on the floating logic board.   The information is copied to the earthy processor board if necessary at initialisation.
« Last Edit: December 03, 2025, 04:41:35 pm by perdrix »
The following users thanked this post: Mickle T.
