I have a dsox 2014 with nand flash corruption. Here's the initial u-boot output from first terminal window:
I followed the titiris method:
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg2136181/#msg2136181I have had some successes, but I keep getting stuck near the final stages of recovery. when entering "go 0x00362000" All I get is:
## Starting application at 0x00362000 ...
nothing ever happens afterwards.
I followed the procedures for USB stick generation and set the file structure the same way, double checked the spelling of the directory folders. I put the same setup on a 64mb fat formatted usb stick and a 16gb exfat formatted usb memory stick. Neither worked.
I repeated the process with 2.37 firmware but still no change.
I formatted the 16gb usb stick in fat32 and no change. still stuck on "Starting application at 0x00362000 ..."
I noticed that the read/write light on any usb card I use never lights up when in the scope.
I tried the same process without a usb stick inserted and the same thing happens.
Is the scope just not reading any of my usb memory cards?
Any troubleshooting ideas?
Thanks guys!
Edit: I have solved my problem and will update here with the procedure soon. A dsox2014 has been saved from the bins!
