Author Topic: EEVBlog 121GW Multimeter Firmware Details  (Read 344144 times)
Offline bateau020
Re: EEVBlog 121GW Multimeter Firmware Details
« Reply #300 on: July 05, 2021, 10:31:02 am »
Just got a new 121GW and it is displaying 2.05 - not sure if its a beta release?
See here: https://www.eevblog.com/forum/testgear/eevblog-121gw-discussion-thread/msg3554407/#msg3554407
You can say many things about Dave, but he certainly provides a certain sense of continuity:
I ask myself this question, why the firmware version 2.04 is not included on Dave's EEVBlog site?
The latest firmware on EEVBlog being 2.02?
I'm a slack arse.
It's now updated.
Offline Sharp
« Reply #301 on: November 14, 2021, 07:26:55 pm »
Hi guys
I have three 121GW Multimeters and have updated them regularly, but the 2.05 is not working – it is rejected…
Any idea why ?
Offline Sharp
« Reply #302 on: November 14, 2021, 08:02:01 pm »
I gave the file another go and it worked  |O
Offline npelov
  • Country: bg
    • Microlab.info
« Reply #303 on: March 23, 2022, 11:05:47 pm »
Why is the firmware changelog in the manual instead in the zip file with the firmware. There is no need to update the manual every time the firmware is updated. I'm curious what was fixed in 2.05...
Offline urbite
« Reply #304 on: July 03, 2022, 02:07:46 pm »
How does one check which firmware version is in the meter. I assume the firmware version is displayed briefly at power on, which in my case displays "U - 1.18".
Does this indicate version 1.18? Asking because there is no v1.18 at https://www.eevblog.com/product/121gw/. The versions go from 1.17 to 1.21
It would be nice if the user manual mentioned how to check which firmware version is installed after an update. Also, it would be helpful if the beginning of the manual would mention that the firmware version is displayed briefly when powered on (if, indeed, this is correct).
UPDATE:  Just upgraded to 2.05 and confirmed that powerup message is version number. Would still be nice to have this info in user manual.
« Last Edit: July 03, 2022, 02:22:08 pm by urbite »
Offline Electrohacker
« Reply #305 on: October 30, 2022, 08:09:37 pm »
First Time caller long time listener
I noticed what I call a bug.  in setup the beep mode reverts to off when I turn the meter off and on again.  This is firmware 2.05
Offline J-R
« Reply #306 on: October 30, 2022, 08:54:13 pm »
After setting b-OFF or b-On, hold the Setup button down until it stops flashing.  That will save the setting permanently.
« Reply #307 on: October 30, 2022, 09:56:57 pm »
good catch, I must have forgot to confirm by a long press.  Thanks.
